s1's avatar
s1
Icon for New Member rankNew Member
2 hours ago
Agilex 5 E-Series 013B Development Kit User Guide SW4.2 (spread spectrum) description is inverted
The description of DIP switch SW4.2 in the Agilex 5 FPGA E-Series 013B Development Kit User Guide (ID 860700, version 2026.10.02) is inverted and contradicts the board schematic.
User guide (Table 4 "Factory Default Switch and Jumper Settings", Table 7 and Table 17 "Switches"):
OFF - enables the -0.5% spread spectrum modulation for the PCIe clock
ON - disables the -0.5% spread spectrum modulation for the PCIe clock
Schematic (a5e013b_soc_dk_schematic_v1p0.pdf, sheet 51 "CLOCK GENERATOR - SI5332 DECAPS", SW4 table):
POS2 ON - SPREAD SPECTRUM = ENABLE
POS2 OFF - SPREAD SPECTRUM = DISABLE (default)
I tested this on the board, and the schematic is correct:
OFF - spread spectrum disabled (factory default)
ON - spread spectrum enabled
The GTS PMA/FEC Direct PHY TX PLL real-time lock status did not report lock on the PCIe reference clock PCIE_EP_REFCLK (pin M24) with SW4.2 ON. With SW4.2 OFF it reports lock.
1 Reply
  • ai_responder's avatar
    ai_responder
    Icon for Community Manager rankCommunity Manager
    Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
    Note: To continue using AI Responder, please start your next inquiry with ai_responder
    Disclaimer: AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
    Thank you very much.
