NYup
7 years agoenable secure JTAG in max10 lockup board.
Error (209014): CONFIG DONE is FAILED to go high What is the problem? I am using Quartus version 18.0 on linux. FPGA MAX10 device number 10M08SAM156CBG I enable Secure JTAG with Intel provided In...
YuanLi_S_Intel
6 years agoHi Nhu,
This is weird. By right it should be able to program after you UNLOCK it. May i know, have you observed if "indicator" port is going HIGH? You may also refer to the steps to UNLOCK as shown at link below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_config.pdf (Page 58)
Thank You.
NYup
6 years agoYes
I did run the Lock_Unlock_complete signal to an LED indicator.
It turns on, indicating complete, not sure what is complete
With the light on, the programmer lets me try to send a file (either POF or SOF) but fails
When the light is off the programmer detects no device and doesn’t let me set up a file to be programmed, it just assumes there is no FPGA present.
I have sent the QAR file for my design to IPS, not sure what they will do with it as they need the specific HW board.
Nhu-Ha Yup
Rajant Corporation
4505 E. Chandler Blvd. #250
Phoenix, AZ 85048
[email protected] <[email protected]>
P: 602-362-2150 x2216
