Hi @JohnT_Intel ,
Thanks for your response.
I had even tried adding destination address using --dst-addr in hssi applicaition. Still I was not able to detect the packet increment count in ifconfig.
Host1:
$ sudo hssi hssi_10g --eth-loopback off --num-packets 50 --src-addr 11:22:33:44:55:66 --dest-addr 04:3f:72:a4:11:bc --src-port 0
10G loopback test
Tx/Rx port: 99
Tx port: 0
Rx port: 0
eth_loopback: off
he_loopback: none
num_packets: 50
packet_length: 64
src_address: 11:22:33:44:55:66
(bits): 0x665544332211
dest_address: 04:3f:72:a4:11:bc
(bits): 0xbc11a4723f04
random_length: fixed
random_payload: incremental
rnd_seed0: 5eed0000
rnd_seed1: 5eed0001
rnd_seed2: 25eed
eth:
No eth interface, so not honoring --eth-loopback. Try using the hssiloopback command instead.
0x40000 ETH_AFU_DFH: 0x1000010000001000
0x40008 ETH_AFU_ID_L: 0xbb370242ac130002
0x40010 ETH_AFU_ID_H: 0x823c334c98bf11ea
0x40030 TRAFFIC_CTRL_CMD: 0x0000000000000000
0x40038 TRAFFIC_CTRL_DATA: 0x0000000100000000
0x40040 TRAFFIC_CTRL_PORT_SEL: 0x0000000000000000
0x40048 AFU_SCRATCHPAD: 0x0000000045324511
0x3c00 number_packets: 0x00000032
0x3c01 random_length: 0x00000000
0x3c02 random_payload: 0x00000000
0x3c03 start: 0x00000000
0x3c04 stop: 0x00000000
0x3c05 source_addr0: 0x44332211
0x3c06 source_addr1: 0x00006655
0x3c07 dest_addr0: 0xa4723f04
0x3c08 dest_addr1: 0x0000bc11
0x3c09 packet_tx_count: 0x00000032
0x3c0a rnd_seed0: 0x5eed0000
0x3c0b rnd_seed1: 0x5eed0001
0x3c0c rnd_seed2: 0x00025eed
0x3c0d pkt_length: 0x00000040
0x3cf4 tx_sta_tstamp: 0x029238c8
0x3cf5 tx_end_tstamp: 0x02923a90
0x3d00 num_pkt: 0xffffffff
0x3d01 pkt_good: 0x00000000
0x3d02 pkt_bad: 0x00000000
0x3d07 avst_rx_err: 0x00000000
0x3d0b rx_sta_tstamp: 0x029427da
0x3d0c rx_end_tstamp: 0xaa91bc27
0x3e00 mac_loop: 0x00000000
HSSI performance:
Selected clock frequency : 402.832 MHz
Latency minimum : 529638 ns
Latency maximum : 6.99681e+09 ns
Achieved Tx throughput : 19.7882 GB/s
No eth interface, so not showing stats. Try using the hssistats command instead.
In Host2,
user@user-OptiPlex-7080:~$ sudo ifconfig enp1s0f0np0
enp1s0f0np0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::694b:f9a2:b595:f22b prefixlen 64 scopeid 0x20<link>
ether 04:3f:72:a4:11:bc txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0 KB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
