Mads_From_Denmark's avatar
Mads_From_Denmark
2 months ago
AI Suite - How to interpret these graphs in Model Analyzer GUI
Hello Altera Community
What can I learn from these subgraphs? I'm not sure how to connect it to the dla layer device file. The compiler told me: [ INFO ] The input graph is split into 9 subgraph(s), FPGA:3 CPU:6.
(unsupported_layer_chains.dot)
There are 9 nodes with "Transpose does not precede an FC layer." and 2 nodes with "Interpolation input not in NCDHW layout"
(hetero_subgraphs_TensorFlow_Frontend_IR_3.dot)
Why is there a node for device subgraph?
Thanks in advance.
  • Thank you for sharing the compiler reports. Below is how to read them, and why DeviceSubgraph appears.
    What you can learn from these subgraphs
    The compiler message:
    means the model does not run as one FPGA graph. OpenVINO HETERO splits it into contiguous islands: 3 on FPGA and 6 on CPU. Each island is a subgraph. Data that crosses FPGA ↔ CPU is copied through host memory, so extra islands usually mean extra latency.
    From your YOLO3 TensorFlow graph, the 9 partitions are:
    FPGA (3) — real DLA compute
    • DeviceSubgraph_8061 (subgraph=15): backbone + conv2d_58 head
    • DeviceSubgraph_8068 (subgraph=20): medium-scale path + conv2d_66 head
    • DeviceSubgraph_8073 (subgraph=26): fine-scale path + conv2d_74 head
    CPU (6) — layout / upsample / outputs
    • Input NHWC→NCHW (Transpose_169) and the stem that stays with it
    • Two FPN upsample islands (up_sampling2d and up_sampling2d_1)
    • Three output NCHW→NHWC transposes (conv2d_58/66/74 BiasAdd → Result)
    Why is there a node named DeviceSubgraph?
    DeviceSubgraph_8061 / _8068 / _8073 are not layers from your Keras/TF model.
    The HETERO plugin groups a run of consecutive FPGA layers into one hetero::DeviceSubgraph node so the top-level (_3) graph can show:
    • CPU ops in full
    • Each FPGA island as one “execute this blob on FPGA AI Suite IP” node
    That is why you see exactly three DeviceSubgraph boxes — they are the FPGA:3 count.
    To see the convolutions inside one box, open the matching file, for example:
    hetero_subgraphs_TensorFlow_Frontend_IR_3_node_DeviceSubgraph_8061_subgraph_#0.dot
  • JohnT_Altera's avatar
    JohnT_Altera
    Can you share the subgraph file and dot file? I am not able zoom in the picture to understand on the issue observed by you.
    JohnT_Altera
    • CPU ops in full
