Mads_From_Denmark's avatar
Mads_From_Denmark
2 months ago
AI Suite - How to interpret these graphs in Model Analyzer GUI
Hello Altera Community What can I learn from these subgraphs? I'm not sure how to connect it to the dla layer device file. The compiler told me: [ INFO ] The input graph is split into 9 subgraph(s),...
  • JohnT_Altera's avatar
    27 days ago
    Thank you for sharing the compiler reports. Below is how to read them, and why DeviceSubgraph appears.
    What you can learn from these subgraphs
    The compiler message:
    The input graph is split into 9 subgraph(s), FPGA:3 CPU:6
    means the model does not run as one FPGA graph. OpenVINO HETERO splits it into contiguous islands: 3 on FPGA and 6 on CPU. Each island is a subgraph. Data that crosses FPGA ↔ CPU is copied through host memory, so extra islands usually mean extra latency.
    From your YOLO3 TensorFlow graph, the 9 partitions are:
    FPGA (3) — real DLA compute
    • DeviceSubgraph_8061 (subgraph=15): backbone + conv2d_58 head
    • DeviceSubgraph_8068 (subgraph=20): medium-scale path + conv2d_66 head
    • DeviceSubgraph_8073 (subgraph=26): fine-scale path + conv2d_74 head
    CPU (6) — layout / upsample / outputs
    • Input NHWC→NCHW (Transpose_169) and the stem that stays with it
    • Two FPN upsample islands (up_sampling2d and up_sampling2d_1)
    • Three output NCHW→NHWC transposes (conv2d_58/66/74 BiasAdd → Result)
    Why is there a node named DeviceSubgraph?
    DeviceSubgraph_8061 / _8068 / _8073 are not layers from your Keras/TF model.
    The HETERO plugin groups a run of consecutive FPGA layers into one hetero::DeviceSubgraph node so the top-level (_3) graph can show:
    • CPU ops in full
    • Each FPGA island as one “execute this blob on FPGA AI Suite IP” node
    That is why you see exactly three DeviceSubgraph boxes — they are the FPGA:3 count.
    To see the convolutions inside one box, open the matching file, for example:
    hetero_subgraphs_TensorFlow_Frontend_IR_3_node_DeviceSubgraph_8061_subgraph_#0.dot
