AI Suite - How to interpret these graphs in Model Analyzer GUI
- 27 days ago
Thank you for sharing the compiler reports. Below is how to read them, and why DeviceSubgraph appears.
What you can learn from these subgraphsThe compiler message:
The input graph is split into 9 subgraph(s), FPGA:3 CPU:6
means the model does not run as one FPGA graph. OpenVINO HETERO splits it into contiguous islands: 3 on FPGA and 6 on CPU. Each island is a subgraph. Data that crosses FPGA ↔ CPU is copied through host memory, so extra islands usually mean extra latency.
From your YOLO3 TensorFlow graph, the 9 partitions are:
FPGA (3) — real DLA compute
- DeviceSubgraph_8061 (subgraph=15): backbone + conv2d_58 head
- DeviceSubgraph_8068 (subgraph=20): medium-scale path + conv2d_66 head
- DeviceSubgraph_8073 (subgraph=26): fine-scale path + conv2d_74 head
CPU (6) — layout / upsample / outputs
- Input NHWC→NCHW (Transpose_169) and the stem that stays with it
- Two FPN upsample islands (up_sampling2d and up_sampling2d_1)
- Three output NCHW→NHWC transposes (conv2d_58/66/74 BiasAdd → Result)
Why is there a node named DeviceSubgraph?
DeviceSubgraph_8061 / _8068 / _8073 are not layers from your Keras/TF model.
The HETERO plugin groups a run of consecutive FPGA layers into one hetero::DeviceSubgraph node so the top-level (_3) graph can show:
- CPU ops in full
- Each FPGA island as one “execute this blob on FPGA AI Suite IP” node
That is why you see exactly three DeviceSubgraph boxes — they are the FPGA:3 count.
To see the convolutions inside one box, open the matching file, for example:
hetero_subgraphs_TensorFlow_Frontend_IR_3_node_DeviceSubgraph_8061_subgraph_#0.dot
Can you share the subgraph file and dot file? I am not able zoom in the picture to understand on the issue observed by you.
- Mads_From_Denmark2 months ago
Yes, the forum won't accept them so I uploaded them to Git
also what is the purpose with the dot files in the visualization folder, They don't seem to be viewable with the model analyzer GUI
madskost/yolo3_fpga_ai_suite_compiled_output
