OFS : Data Path of QSFP from HE_HSSI
Can you try running "sudo fpgainfo phy -B 0xb1"?
Can you also try disabling the loopback by "sudo hssiloopback --loopback disable --pcie-address 0000:b1:00.0"?
- attdoner2 years ago
Hi @JohnT_Intel
[user@user ~]$ sudo fpgainfo phy -B 0x8
Intel Acceleration Development Platform N6001
Board Management Controller NIOS FW version: 131.15.0
Board Management Controller Build version: 3.15.0
//****** PHY ******//
Interface : DFL
Object Id : 0xF100000
PCIe s:b:d.f : 0000:08:00.0
Vendor Id : 0x8086
Device Id : 0xBCCE
SubVendor Id : 0x8086
SubDevice Id : 0x1771
Socket Id : 0x00
Ports Num : 01
Bitstream Id : 0x5010202FB22E12D
Bitstream Version : 5.0.1
Pr Interface Id : 8b153d79-5e54-5416-8096-25480eb9b02f
QSFP0 : Connected
QSFP1 : Connected
//****** HSSI information ******//
HSSI version : 1.0
Number of ports : 8
Port0 :25GbE UP
Port1 :25GbE UP
Port2 :25GbE UP
Port3 :25GbE UP
Port4 :25GbE UP
Port5 :25GbE UP
Port6 :25GbE UP
Port7 :25GbE UP
[user@user ~]$[user@user ~]$ sudo hssiloopback --pcie-address 0000:08:00.0 --loopback disable
args Namespace(loopback='disable', ncsi_ch_sel=None, pcie_address='0000:08:00.0', port=0)
sbdf: 0000:08:00.0
FPGA dev: {'segment': 0, 'bus': 8, 'dev': 0, 'func': 0, 'path': '/sys/class/fpga_region/region0', 'pcie_address': '0000:08:00.0'}
args.hssi_grps[('dfl_dev.3', ['/sys/bus/pci/devices/0000:08:00.0/fpga_region/region0/dfl-fme.0/dfl_dev.3/uio/uio1'], '0000:08:00.0', 21)]
fpga uio dev:dfl_dev.3--------HSSI INFO START-------
DFH :0x3000000010002015
HSSI ID :0x15
DFHv :0.5
guidl :0x99a078ad18418b9d
guidh :0x4118a7cbd9db4a9b
HSSI version :1.0
Firmware Version :1
HSSI num ports :8
Port0 :25GbE
Port1 :25GbE
Port2 :25GbE
Port3 :25GbE
Port4 :25GbE
Port5 :25GbE
Port6 :25GbE
Port7 :25GbE
--------HSSI INFO END-------hssi loopback disabled to port0
[user@user ~]$
