OFS : Data Path of QSFP from HE_HSSI
Do you face the same issue when you have the connection loopback from port 0 to port 1 of the FPGA board?
Hi @JohnT_Intel ,
Testcase1: In Loopback mode: Server1
Here, In server1 I am using HSSI application to send packets. I could see the packets received using hssistats in same Server1. I could see out the values of TX and RX packet counts in hssistats application. This testcase works.
Testcase2: In External Board to Board mode: Server1 -> Server2
Here, In server1 I am using HSSI application to send packets. In server2 I am using normal ifconfig. I could see no packets received in Server2. I could see out the values of TX counts in hssistats application in Server1. Even executed tcpdump in server2. This testcase doesnot work.
Let me know is there anyway I can show that HSSI sending packets to other cards. Since I have only one N6001 and a Mellanox card.
