OFS : Data Path of QSFP from HE_HSSI
HI,
Have you turn off the ethernet loopback on both board? The reason is that the loopback is turn on by default.
Can you provide the log file of 2 system after you have run the "hssi" cmd. Please provide the log after running this command "hssistats [-h] [--pcie-address PCIE_ADDRESS, -P PCIE_ADDRESS]"
Hi @JohnT_Intel ,
Yes I had disabled using --eth-loopback=off. Below logs contains interface stats after executing hssi commands.
In Host1 where N6001 is connected,
Log: "sudo hssi hssi_10g --eth-loopback off --num-packets 100"
log: sudo hssistats
In Host2 where Other NIC,
user@user-OptiPlex-7080:~$ sudo ifconfig enp1s0f0np0
enp1s0f0np0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
ether 04:3f:72:a4:11:bc txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0KB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0 KB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
Host2 (NIC2) is validated with other tests and it receives data. But HE-HSSI applications the packet counts are 0
