attdoner
2 years agoOFS : Data Path of QSFP from HE_HSSI
Hi Team, I am using N6001 with Intel OFS (OFS PCIe Attach) . I wanted to test data transfer from Host1 to Host2 as below. Host1 -> N6001(Port0) -> OtherNIC(Port0) -> Host2. Is there any sample app...
JohnT_Altera
2 years agoHi,
From the screenshot provided, you enable the loopback on your HSSI testing. You will need to disable to loopback if you are communicating between 2 boards.
You may refer to https://ofs.github.io/ofs-2024.2-1/sw/fpga_tools/hssi/hssi/#description on the argument available.
attdoner
2 years agoHi @JohnT_Intel ,
Thanks for the update.
I will test and update the same.
In addition to my queries, whether the ice driver will list any interface in Host for N6001? So that interface will list under 'ip a'/'ifconfig'. With this interface, can I create any application to send and receive packets from board to board without HSSI in-built application?. Is it possible to run DPDK application in this FIM?
Ayshathul Thuhara
