FabriceNs
4 months agoUSB Device Issue on Cyclone V / HPS
Hello, Please find below a description of the USB issue we are experiencing with our Cyclone V / HPS board. To test our USB interface, we integrated the TinyUSB library into our existing firmware a...
- 3 months ago
@FabricNS
Please ignore above issue that wasn't it.
I played some more with the tinyusb code and finally found the problem. It seems the old dwc2 USB controller receive fifo size must be set to a minimum of 119 words. The fix is to edit the tinyusb/src/portable/synopsys/dwc2/dcd_dwc2.c file at the function calc_device_grxfsiz().
The original code is:
TU_ATTR_ALWAYS_INLINE static inline uint16_t calc_device_grxfsiz(uint16_t largest_ep_size, uint8_t ep_count) { return (uint16_t)(13 + 1 + 2 * ((largest_ep_size / 4) + 1) + 2 * ep_count); }I changed it to this:
TU_ATTR_ALWAYS_INLINE static inline uint16_t calc_device_grxfsiz(uint16_t largest_ep_size, uint8_t ep_count) { // Altera Cyclone V SoC DWC2 bug, the minimum grzfsiz is 119 words, i.e. 4*119 = 476 bytes #if defined(TUP_USBIP_DWC2_CV) && TU_CHECK_MCU(OPT_MCU_CV) uint16_t words = (uint16_t)(13 + 1 + 2 * ((largest_ep_size / 4) + 1) + 2 * ep_count); if(words < 119) words = 119; return words; #else return (uint16_t)(13 + 1 + 2 * ((largest_ep_size / 4) + 1) + 2 * ep_count); #endif }You will also need to add OPT_MCU_CV into tinyusb/src/common/tusb_mcu.h:
...... //--------------------------------------------------------------------+ // Geehy //--------------------------------------------------------------------+ #elif TU_CHECK_MCU(OPT_MCU_APM32F0XX) #define TUP_USBIP_FSDEV #define TUP_USBIP_FSDEV_APM32 #define CFG_TUSB_FSDEV_PMA_SIZE 1024u //--------------------------------------------------------------------+ // Altera Cyclone V SoC //--------------------------------------------------------------------+ #elif TU_CHECK_MCU(OPT_MCU_CV) #define TUP_USBIP_DWC2 #define TUP_USBIP_DWC2_CV #define TUP_DCD_ENDPOINT_MAX 16 #endifand also ensure to set it in your tusb_config.h:
#ifndef CFG_TUSB_MCU #define CFG_TUSB_MCU OPT_MCU_CV #endif
FabriceNs
4 months agoI need to request the code from our development team first. I'll get back to you as soon as I receive it.
