FabriceNs's avatar
FabriceNs
4 months ago
USB Device Issue on Cyclone V / HPS
Hello, Please find below a description of the USB issue we are experiencing with our Cyclone V / HPS board. To test our USB interface, we integrated the TinyUSB library into our existing firmware a...
  • TruHy's avatar
    TruHy
    3 months ago
    @FabricNS
    Please ignore above issue that wasn't it.
    I played some more with the tinyusb code and finally found the problem.  It seems the old dwc2 USB controller receive fifo size must be set to a minimum of 119 words.  The fix is to edit the tinyusb/src/portable/synopsys/dwc2/dcd_dwc2.c file at the function calc_device_grxfsiz().
    The original code is:
    TU_ATTR_ALWAYS_INLINE static inline uint16_t calc_device_grxfsiz(uint16_t largest_ep_size, uint8_t ep_count) {
      return (uint16_t)(13 + 1 + 2 * ((largest_ep_size / 4) + 1) + 2 * ep_count);
    I changed it to this:
      // Altera Cyclone V SoC DWC2 bug, the minimum grzfsiz is 119 words, i.e. 4*119 = 476 bytes
    #if defined(TUP_USBIP_DWC2_CV) && TU_CHECK_MCU(OPT_MCU_CV)
      uint16_t words = (uint16_t)(13 + 1 + 2 * ((largest_ep_size / 4) + 1) + 2 * ep_count);
      if(words < 119) words = 119;
      return words;
    #else
    #endif
    You will also need to add OPT_MCU_CV into tinyusb/src/common/tusb_mcu.h:
    // Geehy
    #elif TU_CHECK_MCU(OPT_MCU_APM32F0XX)
      #define TUP_USBIP_FSDEV
      #define TUP_USBIP_FSDEV_APM32
      #define CFG_TUSB_FSDEV_PMA_SIZE 1024u
    #elif TU_CHECK_MCU(OPT_MCU_CV)
      #define TUP_USBIP_DWC2
      #define TUP_USBIP_DWC2_CV
      #define TUP_DCD_ENDPOINT_MAX 16
    #endif
    and also ensure to set it in your tusb_config.h:
    #ifndef CFG_TUSB_MCU
    #define CFG_TUSB_MCU          OPT_MCU_CV
    #endif
