Store custom keys on SDM Agilex3
Hi
I know it's possible to store encryption and siging keys on the SDM for fpga firmware decryption and authentication, but is it possible to store my own keys on it?
I will use the key to decrypt my own software files on the HPS, so I need some way to send the ecrypted software to the SDM then the SDM will use the key to decrypt it and send it back.
Is there any documentation or tutorial for this?
- FawazJ_Altera
You can download the GHRD of Agilex® 5 FPGA E-Series 013B Development Kit, QPDS26.1.1 using the commands below:
git clone --branch QPDS26.1.1_REL_GSRD_PR https://github.com/altera-fpga/agilex5e-ed-gsrd.git
cd dk-a5e013bm16aea/baseline-a55Thank you,
Fawaz
- SueC_Altera
Contributor
Hi torstein18,
Do you have an NDA with Altera? The Agilex 3 Device Security User Guide tells you how to do this, but it is a restricted document, so you have to have an NDA and be signed into MyAltera to get access.
Sue
- torstein18
I have read trough the documentation, but I still don't understand how I can send commands to the SDM from linux running on the HPS. Do I need to install any drivers or do some changes to the device tree. Here is the device tree node I have for the SDM:
firmware { svc { compatible = "intel,agilex5-svc"; method = "smc"; memory-region = <&service_reserved>; iommus = <&smmu 10>; interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>; interrupt-parent = <&intc>; altr,smmu_enable_quirk; fpga_mgr: fpga-mgr { compatible = "intel,agilex5-soc-fpga-mgr"; altr,smmu_enable_quirk; }; temp_volt: hwmon { compatible = "intel,soc64-hwmon"; }; fcs_config: fcs-config { compatible = "intel,agilex5-soc-fcs-config"; }; }; };I have installed the FCS driver:
root@agilex3:~# zcat /proc/config.gz | grep FCS CONFIG_ALTERA_SOCFPGA_FCS_DEBUG=y CONFIG_CRYPTO_DEV_INTEL_FCS=yIs there any other drivers I need?
- SueC_Altera
Contributor
Hi torstein18 - please take a look at this example:
I have to put a screen shot instead of a link get around the forum restrictions. It is on altera-fpga.github.io
Sue
- torstein18
Ok, I will check it out when I get an NDA
