Store custom keys on SDM Agilex3
Hi torstein18,
Do you have an NDA with Altera? The Agilex 3 Device Security User Guide tells you how to do this, but it is a restricted document, so you have to have an NDA and be signed into MyAltera to get access.
Sue
I have read trough the documentation, but I still don't understand how I can send commands to the SDM from linux running on the HPS. Do I need to install any drivers or do some changes to the device tree. Here is the device tree node I have for the SDM:
firmware {
svc {
compatible = "intel,agilex5-svc";
method = "smc";
memory-region = <&service_reserved>;
iommus = <&smmu 10>;
interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>;
interrupt-parent = <&intc>;
altr,smmu_enable_quirk;
fpga_mgr: fpga-mgr {
compatible = "intel,agilex5-soc-fpga-mgr";
temp_volt: hwmon {
compatible = "intel,soc64-hwmon";
fcs_config: fcs-config {
compatible = "intel,agilex5-soc-fcs-config";
};I have installed the FCS driver:
root@agilex3:~# zcat /proc/config.gz | grep FCS
CONFIG_ALTERA_SOCFPGA_FCS_DEBUG=y
CONFIG_CRYPTO_DEV_INTEL_FCS=yIs there any other drivers I need?
- SueC_Altera1 month ago
Contributor
Hi torstein18 - please take a look at this example:
I have to put a screen shot instead of a link get around the forum restrictions. It is on altera-fpga.github.io
Sue
- WeihanT_Altera1 month ago
Moderator
Contributor
Testing to see if I can post the link now:
- torstein181 month ago
This is a dead link:
wget https://github.com/altera-fpga/agilex5e-ed-gsrd/releases/download/QPDS26.1.1_REL_GSRD_PR/a5ed013-devkit-oobe-legacy-baseline.zip
Where can I find it now?
I use Quartus 26.1.1 and DK-A5E013BM16AEA: Agilex® 5 FPGA E-Series 013B Development Kit
