Arria 10 HPS - DMA EMAC reset issue
- 4 months ago
We found the root cause and resolved the issue.
The problem was that the PLL in the FPGA GMII-to-SGMII clock path was not locked. As a result, the required clocks supplied to the HPS EMAC were not valid, and the DMA software reset bit remained asserted:
DMA_BUS_MODE.SWR = 1
This behavior matches the Arria 10 documentation:
When using the FPGA GMII/MII interface, you must have a stable RX clock (emac_clk_rx_i) and TX clock (emac_clk_tx_i) supplied from the PHY to the EMAC before bringing the EMAC out of reset.
The register description for DMA_BUS_MODE.SWR also states that the bit is cleared automatically only after the reset operation has completed in all active GMAC clock domains. Therefore, all PHY input clocks required by the selected interface must be present for the software reset to complete.
In our case, the PLL lock condition could not be determined through the available HPS registers. We were only able to identify the issue using Signal Tap.
To verify the clock path, the FPGA firmware team implemented a counter driven by the relevant clock. The counter showed that the expected clock was not running, which confirmed that the PLL had not locked.
After fixing the PLL configuration and verifying that the clocks were active and stable, the SWR bit cleared successfully and the Ethernet interface started working.
Thank you for the guidance. The recommendation to verify emac_clk_rx_i and emac_clk_tx_i using Signal Tap helped us identify the root cause.
Please confirm whether the U-Boot initialization sequence is correct.
First, make sure the FPGA has entered user mode and that all related soft logic, including the GMII-to-SGMII bridge, PCS, and transceiver path, has been loaded and released from reset.
Next, release reset on the PHY/SGMII side so that valid clocks can be generated.
Then, confirm that both emac_clk_rx_i and emac_clk_tx_i presented to the HPS EMAC are stable and active. If there is no status register for this, Signal Tap or a simple counter can be used for verification.
After that, configure the required System Manager settings, such as phy_intf_sel and fpgaintf_en_3.
Finally, release the EMAC from reset and then trigger the Ethernet / DMA initialization.
You can try troubleshooting in this order first.
BR,
Zheng
