kevinsuresh's avatar
kevinsuresh
1 month ago
Agilex 5/3 FreeRTOS SDK Release
Stable Version: v26.1.1
Quartus Version: 26.1.1
Supported devices: Agilex™ 3 and Agilex™ 5
Source: https://github.com/Ignitarium-Technology/freertos-socfpga
Branch/Tag: v26.1.1
Release Date: October 9, 2026
Hello Everyone,
A new version of the FreeRTOS SDK for Agilex 5/3 is now available. This release contains some fixes, along with UHS-1(SDR12/25/50) support for SD/eMMC.
Visit the GitHub repository for instructions on how to get started.
Features and Comments
FeatureAgilex3Agilex5Agilex3 SMPAgilex5 SMPSupported FeaturesLimitations / Known Issues
A55 bootYesYesYesYesSingle-core boot, Dual-core SMP, Quad-core SMP (Agilex 5)
A76 bootNAYesNAYesSingle-core boot, Dual-core SMP, Quad-core SMP
QSPI bootYesYesYesYes
eMMC bootNTYesNTYes
SD bootNTYesNTYes
NAND bootNoNoNoNo
Clock ManagerYesYesYesYesAPI to get clock speed of different blocks
Reset ManagerYesYesYesYesPeripheral reset assert/de-assert
DMA driverYesYesYesYesMemory-to-Memory, Memory-to-Peripheral and Peripheral-to-Memory
GPIO driverYesYesYesYesWrite, read and interrupt support
Timer driverYesYesYesYesUser-defined and free-running modes
UART driverYesYesYesYesFull-duplex TX and RX
I2C driverNTYesNTYesMaster/Slave mode, standard and fast modes
QSPI driverYesYesYesYesQSPI flash read/write/erase
I3C driverNTYesNTYesMaster mode, I3C and legacy I2C devices
SPI driverNTYesNTYesMaster/Slave mode write and read
NAND driverNoNoNoNo
SDM Mailbox driverYesYesYesYesSDM commands with SIP_SVC
SMMU supportYesYesYesYesStatic identity mapping for cache coherency
SDMMC driverYesYesYesYesStandard and HS HS, and UHS-I (SDR12/25/50) speeds, SDMMC and eMMC devices, FATFS support
Ethernet stackYesYesYesYesTCP/IP, UDP, ICMP, DHCP, IPv4 and IPv6
USB 2.0 stackNTYesNTYesUSB mass storage classTested with a custom board and SOF
USB 3.1 stackYesYesYesYesUSB mass storage operation
WDT driverYesYesYesYesInterrupt or reset on timer expiry
EDAC supportYesYesYesYesError injection and detection for EMAC, USB and QSPI blocksOCRAM not supported
IOSSM driverYesYesYesYesError injection and detection
Bridge driverYesYesYesYesEnable/Disable bridges
Reboot ManagerYesYesYesYesWarm/Cold reboot
FPGA ManagerYesYesYesYesFPGA configuration
Legend:
  • Yes: Feature available and tested
  • No: Feature not available in SDK
  • NA: Not applicable
  • NT: Not tested
Note: If you find any issues, please raise an issue on the GitHub repository.
1 Reply
  • ai_responder's avatar
    ai_responder
    Icon for Community Manager rankCommunity Manager
    Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
    Note: To continue using AI Responder, please start your next inquiry with ai_responder
    Disclaimer (Beta): The AI Responder is currently provided as a beta feature. AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
    Thank you very much.
