Agilex 5 with HPS Cryptographic services and bootflow
Hi rdrr,
Your replies disappeared - I don't know why. I will alert the forum team. But I got the emails.
I'm so sorry you are confused! The part number decoder shows this, in part:
The dev kit is not shown on here because it is an ES device. You can see this by the 0 in the 4th digit place and the ES at the end. Security features are not enabled on ES devices.
For the other two devices you showed, you should look at the Agilex 5 C column for the first one and the Agilex 5 B column for the second device (using the 4th digit again) in the document I linked above.
All security features except for the Cryptographic Services are available on both B and C devices. The table in part shows:
Does that help?
Sue
<Duplicate> can't remove. See question below. https://community.altera.com/discussions/soc-system/agilex-5-with-hps-cryptographic-services-and-bootflow/348877/replies/348903
