RolandoS_Altera's avatar
RolandoS_Altera
11 months ago
25.3 PRO Release
Version: Release 25.3 PRO
Quartus Build/TAG: B109/QPDS25.3_REL_GSRD_PR
Release Date: October 10, 2025
Device Affected: Agilex™ 3, Agilex™ 5, Agilex™ 7, Startix® 10, Arria® 10
Release Type: Major release/Binary release
Binary Release Path: http://releases.rocketboards.org/2025.10/
Major Features Released
  • Support of GHRD 2.0 in Agilex™ 5 which includes foundational boot to Linux, ability to create compatible phase 2 bitstreams, parameterized HPS for maximum performance and best practices. Support of GSRD 2.0 Yocto layers for the Agilex 5 E-Series Premium DevKit with OOBE daughtercard for the GHRD 2.0 baseline design. Agilex 5 GSRD Development User Experience Improvement through KAS using a graphical/text interface to configure a limited number of high-level options on top of simplified Yocto recipes. - GSRD 2.0 with Kas Build System
  • Support for running Agilex 5 Simics Simulation under the GSRD 2.0 framework. Booting from SD Card and QSPI is supported. -  Exercising Simics Simulation from GSRD 2.0
  • Support GHRD and GSRD for Agilex™ M-Series PRQ HBM2e for DK-Sl-AGM039EA development kit. The GSRD is capable of booting to Linux. - Build the GSRD for DK-DEV-AGM039EA
  • Hypervisor Multi-OS Support Example, demonstrating Linux and Zephyr running side-by-side in the HPS cluster. - HPS Xen Hypervisor GSRD System Example Design: Agilex™ 3 FPGA and SoC C-Series Development Kit
  • Support for monitoring of SEU errors from the SDM in the HPS in Agilex™ 7.
  • Add capability to measure the latency of Linux SMC calls.
  • Support Nios V Lockstep application with a fail-safe mechanism
  • I use uboot 26.04 but cannot get usb to work on my DK-A5E065A premium devkit.
    In linux it works fine. USB Drive is recognized with no problems.
    I get this output in uboot:
    => usb start
    starting USB...
    Bus usb@10b00000: Port not available.
    Bus usb31@11000000: probe failed, error -110
    No USB controllers found
           scanning usb for storage devices... 0 Storage Device(s) found
    Any idea how to fix this? Or is this a known issue in 26.1.1?
  • Hello Team,
    We are testing the USB 3.1 interface on Agilex 5 using Quartus version 25.1. All the required drivers have been enabled, but the device is still being detected as USB 2.0.
    We noticed that there is a workaround mentioned for this issue in version 25.3. Could you please confirm whether this USB 3.0 detection issue is expected in Quartus 25.1?
    If yes, would applying the workaround or changes introduced in 25.3 help resolve the issue in version 25.1 as well?
      • Arun_Prabakatr's avatar
        Arun_Prabakatr
        Hi Team
        I’ve updated our log, node, and kernel  config files below. Please let us know if we’re missing anything
        we are using
        HP x796w USB 3.2 Flash Drive-Pendrive
        Striff USB to Type C Connector
    • whitepau_altera's avatar
      whitepau_altera
      Hello Arun,
      thanks for your question. I assume you are following our guide to enable USB 3.1 device mode on the Agilex™ 5 HPS for the Agilex™ 5 E-series premium devkit. Please note that this guide only started working in Quartus® Prime 25.1.1; not 25.1.
      USB 3.1 Gen-1 Controller Tutorial Example Design User Guide
      How can you tell that the Agilex™ 5 devkit is detected as USB 2.0? I checked the device using USBTreeView and it enumerated as USB 3.2 Gen 1 (which, confusingly, is basically the same thing as USB 3.1 Gen 1 and USB 3.0). Are you sure the upstream port you connected to supports USB 3.1?
