RolandoS_Altera
1 year ago25.3 PRO Release
Version: Release 25.3 PRO Quartus Build/TAG: B109/QPDS25.3_REL_GSRD_PR Release Date: October 10, 2025 Device Affected: Agilex™ 3, Agilex™ 5, Agilex™ 7, Startix® 10, Arria® 10 Release Type: Major ...
RolandoS_Altera
1 month agoHello
USB3.1 requires signals from the fabric to work, so you need to have the fabric full configured if you want to use USB3.1. Can you try to perform FPGA configuration from U-Boot and then try to access the USB port?
In https://altera-fpga.github.io/rel-26.1.1/embedded-designs/agilex-5/e-series/premium-065a/boot-examples/ug-linux-boot-agx5e-premium-065a/#boot-from-sd-card you can see how you can perform FPGA config from U-Boot.
load mmc 0:1 \${loadaddr} ghrd.core.rbf; <-- If you rbf is in SD card
fpga load 0 \${loadaddr} \${filesize};
bridge enable;
You can also take the rbf to the system using tftp.
Rolando
dave_the_fave
1 month agoHi Rolando
Thanks for the tip. This is true... Once i loaded the core.rbf, usb works!
Dave
