RolandoS_Altera
11 months ago25.3 PRO Release
Version: Release 25.3 PRO Quartus Build/TAG: B109/QPDS25.3_REL_GSRD_PR Release Date: October 10, 2025 Device Affected: Agilex™ 3, Agilex™ 5, Agilex™ 7, Startix® 10, Arria® 10 Release Type: Major ...
Arun_Prabakatr
10 months agoHi White
I am also getting those prints print QPD25.1 But still
but while testing the version it detects as 2.0 all time
whitepau_altera
Contributor
10 months agoHi Arun,
There is a utility called `lsusb` that you can add to your Yocto image. Add the following IMAGE_INSTALL line to gsrd-socfpga/agilex5_dk_a5e065bb32aes1-gsrd-rootfs/conf/local.conf:
# CONF_VERSION is increased each time build/conf/ changes incompatibly and is used to
# track the version of this file when it was generated. This can safely be ignored if
# this doesn't mean anything to you.
CONF_VERSION = "2"
# support lsusb
IMAGE_INSTALL:append = " usbutils"Then rebuilt your SD card image with
bitbake gsrd-console-imageThe output I see when the PNY USB stick I linked above is plugged in:
root@agilex5dka5e065bb32aes1:~# lsusb --tree
/: Bus 001.Port 001: Dev 001, Class=root_hub, Driver=xhci-hcd/1p, 480M
/: Bus 002.Port 001: Dev 001, Class=root_hub, Driver=xhci-hcd/1p, 10000M
|__ Port 001: Dev 002, If 0, Class=Mass Storage, Driver=usb-storage, 5000M
root@agilex5dka5e065bb32aes1:~#This shows that there are 2 USB hosts, and that bus 2 is the USB 3 host. If you poll the devices and look at usb2 instead of usb1, we see USB 3 compatibility.
root@agilex5dka5e065bb32aes1:~# cat /sys/devices/platform/soc\@0/11000000.usb1/xhci-hcd.0.auto/usb2/2-1/version
3.20
