25.3 PRO Release
Hi Team
I’ve updated our log, node, and kernel config files below. Please let us know if we’re missing anything
we are using
HP x796w USB 3.2 Flash Drive-Pendrive
Striff USB to Type C Connector
Hello Arun, thanks for sharing.
I suspect the problem is your USB to Type C connector; those adapters can sometimes silently downgrade USB speeds. I tested using a USB mass storage device that has both a USB-A and a USB-C port, and I verified USB SS speeds using CrystalDiskMark and fio.
PNY DUO LINK V3 USB 3.2 Gen 2 Dual Flash Drive
I've attached the logs I see when I attach this USB Stick:
root@agilex5e:~# dmesg | grep USB
[ 1.480973] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 1.510119] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 1.517753] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.525956] hub 1-0:1.0: USB hub found
[ 1.542405] hub 2-0:1.0: USB hub found
[ 4.732358] usbhid: USB HID core driver
[ 37.071576] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[ 37.446512] usb-storage 1-1:1.0: USB Mass Storage device detected
[ 38.497114] scsi 0:0:0:0: Direct-Access PNY USB 3.2.2 FD PMAP PQ: 0 ANSI: 6During U-Boot:
SOCFPGA_AGILEX5 # usb start
starting USB...
Bus usb@10b00000: Port not available.
Bus usb31@11000000: probe failed, error -110
No USB controllers found
scanning usb for storage devices... 0 Storage Device(s) found
SOCFPGA_AGILEX5 #Please note that I built this Linux image using the newer GSRD 2.0 (tested with Quartus® Prime 25.3), which uses Kas to manage Yocto layers, but the Linux configurations should be the same as the 'classic' GSRD.
Rebuilding GSRD 2.0 Binaries
- Arun_Prabakatr1 year ago
Hello Team
We have tested this on other iMX boards where USB 3.0 detection works as expected.Also we have validated with other pendrives we have still it detects as 2.0 Now I need to validate USB host mass storage on QPD25.1. - Arun_Prabakatr1 year ago
Hi White
I am also getting those prints print QPD25.1 But stillbut while testing the version it detects as 2.0 all time
- whitepau_altera1 year ago
Contributor
Hi Arun,
There is a utility called `lsusb` that you can add to your Yocto image. Add the following IMAGE_INSTALL line to gsrd-socfpga/agilex5_dk_a5e065bb32aes1-gsrd-rootfs/conf/local.conf:
# CONF_VERSION is increased each time build/conf/ changes incompatibly and is used to # track the version of this file when it was generated. This can safely be ignored if # this doesn't mean anything to you. CONF_VERSION = "2" # support lsusb IMAGE_INSTALL:append = " usbutils"Then rebuilt your SD card image with
bitbake gsrd-console-imageThe output I see when the PNY USB stick I linked above is plugged in:
root@agilex5dka5e065bb32aes1:~# lsusb --tree /: Bus 001.Port 001: Dev 001, Class=root_hub, Driver=xhci-hcd/1p, 480M /: Bus 002.Port 001: Dev 001, Class=root_hub, Driver=xhci-hcd/1p, 10000M |__ Port 001: Dev 002, If 0, Class=Mass Storage, Driver=usb-storage, 5000M root@agilex5dka5e065bb32aes1:~#This shows that there are 2 USB hosts, and that bus 2 is the USB 3 host. If you poll the devices and look at usb2 instead of usb1, we see USB 3 compatibility.
root@agilex5dka5e065bb32aes1:~# cat /sys/devices/platform/soc\@0/11000000.usb1/xhci-hcd.0.auto/usb2/2-1/version 3.20 - BoonBengT_Altera10 months ago
Moderator
Dear Arun_Prabakatr,
Since clarification has been provided and no further follow‑up questions have been raised, we will assume the issue has been resolved.This thread will now be transitioned to community support, where other users can continue to assist with any additional inquiries.
For new questions, please feel free to open a fresh thread — we’ll be happy to support you there.
Thank you for being part of the community!
Altera Technical Support
