Warning: (vsim-3473) Component instance "U1 : ALTPLL_0001_0002" is not bound.
Hi everyone,
I've generated PLL by Quartus 18.1 Lite MegaWizard .(C0,100Mhz-> 125MHz).
Then I've built a very simple project in ModelSim 10.5B with above mentioned PLL component.
But when I'm trying to simulate the project, I'm getting a such kind warning:
"Warning: (vsim-8684) No drivers exist on out port /altpll_0001_tb/UUT1/CLK_OUT".
it seems that ModelSim cannot recognize a MegaWizard generated component...
What Should I do?
P.S. I've attached a project to this message
- Vicky1
Hi Alex,
You can ignore the warnings, BTW are you getting desired result in simulation?
please provide screenshot.
Let me know, If you have any different concern.
Vicky
- AGofs
- Vicky1
Can you please check with Native link simulation?
https://www.youtube.com/watch?v=PmVVXQchv2c
this issue may occur when simulation process missing any file or sequence.
refer the attachment using Native link.
Vicky
- AGofs
Hi Vicky,
I've made successful simulation with ALTPLL core for Cyclone-4 with Native Link .
But when I'm trying to execute simulation with PLL core for Cyclone-5, then I'm getting such error:
# ** Error: (vcom-7) Failed to open design unit file "C:/Alex/my_designs/18_1/PLL/PLL_001/cyclone_V/PLL_50MHz.vho" in read mode.
# No such file or directory. (errno = ENOENT)
# End time: 13:11:25 on May 13,2019, Elapsed time: 0:00:00
# Errors: 1, Warnings: 0
# ** Error: C:/intelFPGA_lite/18.1/modelsim_ase/win32aloem/vcom failed.
# Error in macro ./PLL_001_run_msim_rtl_vhdl.do line 8
# C:/intelFPGA_lite/18.1/modelsim_ase/win32aloem/vcom failed.
# while executing
# "vcom -93 -work work {C:/Alex/my_designs/18_1/PLL/PLL_001/cyclone_V/PLL_50MHz.vho}"
In addition I'm sending you another project with PLL.
What file or sequence is missing?
P.S. I've made simulation of LPM_counter with Native link for Cyclone 5 component and it works successfully...
Maybe the problem with Cyclone5 pll?
- AGofs
Hi Vicky,
I've received the project and simulated it.
It works properly.
Now , explain me please what did you change at the code?
- Vicky1
I haven`t changed anything in your project, just performed the simulation using native link settings as suggested in my second post.
As I told earlier, it might happen due to all modules/submodules are not in single directory so here in case of native link script will take care of that.
Should I consider that case to be closed?
Vicky
- AGofs
Thank you Vicky, I've simulated some additional projects with PLL via native Link. Yes, it works! Thank you for your advice! But I have a question in principle: is possible at all to simulate projects with PLL (and other IP-cores) directly via ModelSim without native Link?
- Vicky1
off course it is available. As I told earlier, create project in ModelSim which consists of design (All, top & submodules) & testbench in single directory( for simplicity).
In case of IP, create/generate the HDL file for that & add into ModelSim project & Perform Compilation, Simulation.
Vicky
