AGofs
7 years agoWarning: (vsim-3473) Component instance "U1 : ALTPLL_0001_0002" is not bound.
Hi everyone, I've generated PLL by Quartus 18.1 Lite MegaWizard .(C0,100Mhz-> 125MHz). Then I've built a very simple project in ModelSim 10.5B with above mentioned PLL component. But when I'm tryi...
Vicky1
7 years agoHi,
I haven`t changed anything in your project, just performed the simulation using native link settings as suggested in my second post.
As I told earlier, it might happen due to all modules/submodules are not in single directory so here in case of native link script will take care of that.
Should I consider that case to be closed?
Vicky
AGofs
7 years agoThank you Vicky,
I've simulated some additional projects with PLL via native Link.
Yes, it works! Thank you for your advice!
But I have a question in principle: is possible at all to simulate projects with PLL (and other IP-cores) directly via ModelSim without native Link?
