9 years agoVHDL "Quantum" bug
Hi all,
I hope nobody has written about this before. I took a look but I found nothing... I'm a VHDL newbie and I'm facing an issue which is driving me crazy. The thing is that I have designed and implemented a VHDL component, pretty complex if I may say. I coded the RTL model, I refactorized and optimized the code and I checked the RTL netlist to check that it matches with my design. Everything OK. The simulation works as expected too. The problem comes when I synthetise the design for my DE0 NANO board. I can see that the design works but some parts don't work as expected. There's clearly a bug. After checking all my code, I found nothing so I just added some out ports to the entity to check them with a logic analyser. Those ports add no logic. I just map some internal signals to them to try to monitor what's going on. However, once I map those signals, everything works as expected. No bugs. Nothing. If I remove the debug ports, the problem appears again. I don't think this is a speed problem as the maximum frequency I'm using is 1MHz. I also checked all the code and I optimised it for synthesis. I can see using Quartus rtl map viewer that no extra logic is added. Any clue of what can be hapening? Why there's no bug if I add debuging ports to my entity whilst the design doesn't work well if I remove those ports? Thanks a lot in advance. Cheers, Javier4 Replies
This sounds like some sort of timing problem - changing the output will change the fit seed and re-route the design, which may now mean that a route that previously failed is a different length that now works.
Do you have timing constraints for the design? How are you using a 1MHz clock? is it logic generated? these are notorious for creating timing problems. Have you synchronised all asynchronous inputs properly? - Altera_Forum
Hi Tricky,
Sorry for my delayed reply and thank you very much for your reply to my questions. Actually I considered to add timimg constraints to my design but as the frequency is relatively "low" I thought that it may not be worthy. I certainly was wrong so I will start reading about TimeQuest, timing constraints and SDC in order to learn and apply it to my design. One more question if I may: Another problem that I had (which clearly seems to be the same) is that some register loopbacks that I had on my design didn't work even when the simulation was perfect. I read, I guess in Quartus Handbook, that register loopbacks should be avoided so I added an extra register on the loopback path and an extra clock cycle and then everything worked out. So I would like to know if this register loopback issue could be fixed with timing constraints as well or if I should keep the registers that I placed on the loopback path. Sorry for all the questions but I still have a lot to learn here :) Thanks for your time in advance. Regards, Javier - Altera_Forum
Not quite sure what you mean by "register loopback"? did you mean logic loops? logic loops are certainly a problem and can only be fixed by removing them.
Yep, That's it.
Thanks, Javier
