9 years agoVHDL "Quantum" bug
Hi all, I hope nobody has written about this before. I took a look but I found nothing... I'm a VHDL newbie and I'm facing an issue which is driving me crazy. The thing is that I have desi...
9 years agoHi Tricky,
Sorry for my delayed reply and thank you very much for your reply to my questions. Actually I considered to add timimg constraints to my design but as the frequency is relatively "low" I thought that it may not be worthy. I certainly was wrong so I will start reading about TimeQuest, timing constraints and SDC in order to learn and apply it to my design. One more question if I may: Another problem that I had (which clearly seems to be the same) is that some register loopbacks that I had on my design didn't work even when the simulation was perfect. I read, I guess in Quartus Handbook, that register loopbacks should be avoided so I added an extra register on the loopback path and an extra clock cycle and then everything worked out. So I would like to know if this register loopback issue could be fixed with timing constraints as well or if I should keep the registers that I placed on the loopback path. Sorry for all the questions but I still have a lot to learn here :) Thanks for your time in advance. Regards, Javier
