9 years agoVHDL "Quantum" bug
Hi all, I hope nobody has written about this before. I took a look but I found nothing... I'm a VHDL newbie and I'm facing an issue which is driving me crazy. The thing is that I have desi...
9 years agoThis sounds like some sort of timing problem - changing the output will change the fit seed and re-route the design, which may now mean that a route that previously failed is a different length that now works.
Do you have timing constraints for the design? How are you using a 1MHz clock? is it logic generated? these are notorious for creating timing problems. Have you synchronised all asynchronous inputs properly?
