8 years ago
VHDL Code for a Mealy machine with two inputs and one output.
Hi guys, I'm new here. What would be the VDHL code for this Mealy machine? Thanks
A sequential circuit with two Dflip-flops Aand B, two inputs, xand y; and one output z
specified by the following next-state and output equations.
A(t +1)=xy’ +xB
B(t +1)=xA+xb’
z=A
    Why not show the code you've written and what problems you're having
    library ieee;
    use ieee.std_logic_1164.all;
    entity lab2exercise2 is
    port
    clk : in std_logic;
    data_in1 : in std_logic;
    data_in2 : in std_logic;
    reset : in std_logic;
    data_out : out std_logic_vector(1 downto 0)
    end lab2exercise2;
    architecture rtl of lab2exercise2 is
    -- Build an enumerated type for the state machine
    type state_type is (a, b, c, d);
    -- Register to hold the current state
    signal state : state_type;
    signal clk_1hz : std_logic:= '0';
    begin
    process(clk)
    variable counter : integer := 0;
    variable edge_toggle : std_logic := '0';
    begin
    if (rising_edge(clk)) then
    counter := counter + 1;
    if (counter = 25000000) then
    edge_toggle := not edge_toggle;
    counter := 0;
    end if;
    end if;
    clk_1hz <= edge_toggle;
    end process;
    process (clk_1hz, reset)
    begin
    if reset = '1' then
    state<= a;
    elsif (rising_edge(clk_1hz)) then
    -- Determine the next state synchronously, based on
    -- the current state and the input
    case state is
    when a=>
    if((data_in1 = '0') & (data_in2 = '0'))then
    state<=a;
    if((data_in1 = '1') & (data_in2 = '0'))then
    state<=a;
    if((data_in1 = '1') & (data_in2 = '1')) then
    state<=a;
    else
    state<=c;
    end if;
    when b=>
    if ((data_in1 = '0') & (data_in2 = '0')) then
    state<=a;
    else if ((data_in1 = '1') & (data_in2 = '0'))then
    state<=d;
    else if ((data_in1 = '1') & (data_in2 = '1'))then
    state<=d;
    else
    state<=c;
    end if;
    when c=>
    if ((data_in1 = '1') & (data_in2 = '0')) then
    state<=a;
    else if ((data_in1 = '1') & (data_in2 = '1')) then
    state<=a;
    else if ((data_in1 = '0') & (data_in2 = '1')) then
    state<=d;
    else
    state<=b;
    end if;
    when d=>
    if ((data_in1 = '0') & (data_in2 = '1'))then
    state<=d;
    else if((data_in1 = '1') & (data_in2 = '0')) then
    state<=d;
    else if((data_in1 = '1') & (data_in2 = '1')) then
    state<=d;
    else
    state<=b;
    end if;
    end case;
    end if;
    end process;
    -- Determine the output based only on the current state
    -- and the input (do not wait for a clock edge).
    process (state, data_in1, data_in2)
    begin
    case state is
    when a=>
    data_out<= "000";
    data_out<= "000";
    data_out<= "000";
    else
    data_out<= "010";
    end if;
    when b=>
    data_out<= "000";
    data_out<= "011";
    data_out<= "011";
    else
    data_out<= "010";
    end if;
    when c=>
    data_out<= "100";
    data_out<= "100";
    data_out<= "111";
    else
    data_out<= "101";
    end if;
    when d=>
    data_out<= "111";
    data_out<= "111";
    data_out<= "111";
    else
    data_out<= "111";
    end if;
    end case;
    end process;
    end rtl;
    This is my code. I tried running it but I always get error 10500 at lines "when b=>, when c=> and when d=>" and "end processes".
    1. It`s syntax error about If statement, follow below syntax,
    if condition1 then
    target := expression1;
    elsif condition2 then
    target := expression2;
    elsif conditionN-1 then
    target := expressionN-1;
    else
    target := expressionN;
    end if;
    2. if((data_in1 = '0') & (data_in2 = '0'))then -------- Here replace “&” with and
    3. data_out<= "000"; ----- here data_out is 2 bit so assign 2 bits like : data_out<= "00";
    Best Regards
    Vikas Jathar
    Already edited the code but i still get errors at when b=>, when c=> and when d=>" and "end processes".
    All of the errors are 10500 VHDL Syntax error at near text "when"; expecting "if", identifier, etc...sorry couldn't really recall it.
    I would suggest go through the VHDL Basic online training,
    https://www.altera.com/support/training/course/ohdl1110.html
    check modified code,
    library ieee;
    port
    clk    : in    std_logic;
    end lab2exercise2;
    begin
    process(clk)
    begin
    counter := 0;
    end if;
    end if;
    end process;
    begin
    if reset = '1' then
    state<= a;
    case state is
    when a=>
    if((data_in1 = '0') and (data_in2 = '0'))then
    state<=a;
    elsif((data_in1 = '1') and (data_in2 = '0'))then
    state<=a;
    elsif((data_in1 = '1') and (data_in2 = '1')) then
    state<=a;
    else
    state<=c;
    end if;
    when b=>
    if ((data_in1 = '0') and (data_in2 = '0')) then
    state<=a;
    elsif ((data_in1 = '1') and (data_in2 = '0'))then
    state<=d;
    elsif ((data_in1 = '1') and (data_in2 = '1'))then
    state<=d;
    else
    state<=c;
    end if;
    when c=>
    if ((data_in1 = '1') and (data_in2 = '0')) then
    state<=a;
    elsif ((data_in1 = '1') and (data_in2 = '1')) then
    state<=a;
    elsif ((data_in1 = '0') and (data_in2 = '1')) then
    state<=d;
    else
    state<=b;
    end if;
    when d=>
    if ((data_in1 = '0') and (data_in2 = '1'))then
    state<=d;
    elsif((data_in1 = '1') and (data_in2 = '0')) then
    state<=d;
    state<=d;
    else
    state<=b;
    end if;
    end case;
    end if;
    end process;
    begin
    case state is
    when a=>
    data_out<= "00";
    data_out<= "00";
    data_out<= "00";
    else
    data_out<= "01";
    end if;
    when b=>
    data_out<= "00";
    data_out<= "11";
    data_out<= "11";
    else
    data_out<= "10";
    end if;
    when c=>
    data_out<= "10";
    data_out<= "10";
    data_out<= "11";
    else
    data_out<= "10";
    end if;
    when d=>
    data_out<= "11";
    data_out<= "11";
    data_out<= "11";
    else
    data_out<= "11";
    end if;
    end case;
    end process;
    end rtl;
    Best Regards
    Vikas Jathar
    in VHDL, & is the concatenate operator, not the "and" operator.
    You need to replace all & with and
    Have you resolved the issue?
    Do you need further assistance?
    Best Regards
    Vikas Jathar
  • Abe's avatar
    Abe
    Here's the corrected code.. see if you can find out your basic mistakes.. This one compiles without any issues.
    library ieee;
    port (
          clk      : in std_logic;
          data_out : out std_logic_vector(2 downto 0)
    end lab2exercise2;
    begin
    process(clk)
      begin
           counter := 0;
        end if;
      end if;
    end process;
    begin
      if reset = '1' then
        state<= a;
      case state is
        when a=>
            state<=a;
          elsif(data_in1 = '1' and data_in2 = '0')then
            state<=a;
            state<=a;
          else
            state<=c;
          end if;
        when b=>
            state<=a;
            state<=d;
            state<=d;
          else
            state<=c;
          end if;
        when c=>
            state<=a;
            state<=a;
            state<=d;
          else
            state<=b;
          end if;
        when d=>
            state<=d;
            state<=d;
            state<=d;
          else
            state<=b;
          end if;
      end case;
     end if;
    end process;
    begin
      case state is
        when a=>
            data_out<= "000";
            data_out<= "000";
            data_out<= "000";
          else
            data_out<= "010";
          end if;
        when b=>
            data_out<= "000";
            data_out<= "011";
            data_out<= "011";
          else
            data_out<= "010";
          end if;
        when c=>
            data_out<= "100";
            data_out<= "100";
            data_out<= "111";
          else
            data_out<= "101";
          end if;
        when d=>
            data_out<= "111";
            data_out<= "111";
            data_out<= "111";
          else
            data_out<= "111";
          end if;
        end case;
      end process;
    end rtl;
