8 years agoVHDL Code for a Mealy machine with two inputs and one output.
Hi guys, I'm new here. What would be the VDHL code for this Mealy machine? Thanks A sequential circuit with two Dflip-flops Aand B, two inputs, xand y; and one output z specified by the followi...
Abe
8 years agoHere's the corrected code.. see if you can find out your basic mistakes.. This one compiles without any issues.
library ieee;
use ieee.std_logic_1164.all;
entity lab2exercise2 is
port (
clk : in std_logic;
data_in1 : in std_logic;
data_in2 : in std_logic;
reset : in std_logic;
data_out : out std_logic_vector(2 downto 0)
end lab2exercise2;
architecture rtl of lab2exercise2 is
-- Build an enumerated type for the state machine
type state_type is (a, b, c, d);
-- Register to hold the current state
signal state : state_type;
signal clk_1hz : std_logic:= '0';
begin
process(clk)
variable counter : integer := 0;
variable edge_toggle : std_logic := '0';
begin
if (rising_edge(clk)) then
counter := counter + 1;
if (counter = 25000000) then
edge_toggle := not edge_toggle;
counter := 0;
end if;
end if;
clk_1hz <= edge_toggle;
end process;
process (clk_1hz, reset)
begin
if reset = '1' then
state<= a;
elsif (rising_edge(clk_1hz)) then
-- Determine the next state synchronously, based on
-- the current state and the input
case state is
when a=>
if((data_in1 = '0') and (data_in2 = '0'))then
state<=a;
elsif(data_in1 = '1' and data_in2 = '0')then
state<=a;
elsif((data_in1 = '1') and (data_in2 = '1')) then
state<=a;
else
state<=c;
end if;
when b=>
if ((data_in1 = '0') and (data_in2 = '0')) then
state<=a;
elsif ((data_in1 = '1') and (data_in2 = '0'))then
state<=d;
elsif ((data_in1 = '1') and (data_in2 = '1'))then
state<=d;
else
state<=c;
end if;
when c=>
if ((data_in1 = '1') and (data_in2 = '0')) then
state<=a;
elsif ((data_in1 = '1') and (data_in2 = '1')) then
state<=a;
elsif ((data_in1 = '0') and (data_in2 = '1')) then
state<=d;
else
state<=b;
end if;
when d=>
if ((data_in1 = '0') and (data_in2 = '1'))then
state<=d;
elsif((data_in1 = '1') and (data_in2 = '0')) then
state<=d;
state<=d;
else
state<=b;
end if;
end case;
end if;
end process;
-- Determine the output based only on the current state
-- and the input (do not wait for a clock edge).
process (state, data_in1, data_in2)
begin
case state is
when a=>
data_out<= "000";
elsif((data_in1 = '1') and (data_in2 = '0'))then
data_out<= "000";
data_out<= "000";
else
data_out<= "010";
end if;
when b=>
data_out<= "000";
data_out<= "011";
data_out<= "011";
else
data_out<= "010";
end if;
when c=>
data_out<= "100";
data_out<= "100";
data_out<= "111";
else
data_out<= "101";
end if;
when d=>
data_out<= "111";
data_out<= "111";
data_out<= "111";
else
data_out<= "111";
end if;
end case;
end process;
end rtl;
