8 years agoVHDL Code for a Mealy machine with two inputs and one output.
Hi guys, I'm new here. What would be the VDHL code for this Mealy machine? Thanks A sequential circuit with two Dflip-flops Aand B, two inputs, xand y; and one output z specified by the followi...
8 years agolibrary ieee;
use ieee.std_logic_1164.all; entity lab2exercise2 is port ( clk : in std_logic; data_in1 : in std_logic; data_in2 : in std_logic; reset : in std_logic; data_out : out std_logic_vector(1 downto 0) ); end lab2exercise2; architecture rtl of lab2exercise2 is -- Build an enumerated type for the state machine type state_type is (a, b, c, d); -- Register to hold the current state signal state : state_type; signal clk_1hz : std_logic:= '0'; begin process(clk) variable counter : integer := 0; variable edge_toggle : std_logic := '0'; begin if (rising_edge(clk)) then counter := counter + 1; if (counter = 25000000) then edge_toggle := not edge_toggle; counter := 0; end if; end if; clk_1hz <= edge_toggle; end process; process (clk_1hz, reset) begin if reset = '1' then state<= a; elsif (rising_edge(clk_1hz)) then -- Determine the next state synchronously, based on -- the current state and the input case state is when a=> if((data_in1 = '0') & (data_in2 = '0'))then state<=a; if((data_in1 = '1') & (data_in2 = '0'))then state<=a; if((data_in1 = '1') & (data_in2 = '1')) then state<=a; else state<=c; end if; when b=> if ((data_in1 = '0') & (data_in2 = '0')) then state<=a; else if ((data_in1 = '1') & (data_in2 = '0'))then state<=d; else if ((data_in1 = '1') & (data_in2 = '1'))then state<=d; else state<=c; end if; when c=> if ((data_in1 = '1') & (data_in2 = '0')) then state<=a; else if ((data_in1 = '1') & (data_in2 = '1')) then state<=a; else if ((data_in1 = '0') & (data_in2 = '1')) then state<=d; else state<=b; end if; when d=> if ((data_in1 = '0') & (data_in2 = '1'))then state<=d; else if((data_in1 = '1') & (data_in2 = '0')) then state<=d; else if((data_in1 = '1') & (data_in2 = '1')) then state<=d; else state<=b; end if; end case; end if; end process; -- Determine the output based only on the current state -- and the input (do not wait for a clock edge). process (state, data_in1, data_in2) begin case state is when a=> if((data_in1 = '0') & (data_in2 = '0'))then data_out<= "000"; if((data_in1 = '1') & (data_in2 = '0'))then data_out<= "000"; if((data_in1 = '1') & (data_in2 = '1')) then data_out<= "000"; else data_out<= "010"; end if; when b=> if ((data_in1 = '0') & (data_in2 = '0')) then data_out<= "000"; else if ((data_in1 = '1') & (data_in2 = '0'))then data_out<= "011"; else if ((data_in1 = '1') & (data_in2 = '1'))then data_out<= "011"; else data_out<= "010"; end if; when c=> if ((data_in1 = '1') & (data_in2 = '0')) then data_out<= "100"; else if ((data_in1 = '1') & (data_in2 = '1')) then data_out<= "100"; else if ((data_in1 = '0') & (data_in2 = '1')) then data_out<= "111"; else data_out<= "101"; end if; when d=> if ((data_in1 = '0') & (data_in2 = '1'))then data_out<= "111"; else if((data_in1 = '1') & (data_in2 = '0')) then data_out<= "111"; else if((data_in1 = '1') & (data_in2 = '1')) then data_out<= "111"; else data_out<= "111"; end if; end case; end process; end rtl; This is my code. I tried running it but I always get error 10500 at lines "when b=>, when c=> and when d=>" and "end processes".
