10 years agoVerilog Error
Could you please let me know how to declare a synthesizable array of constants? The constants are shown in the define directive. The below is giving an error. I am new to verilog .
Thanks `define DATA_0 1 `define DATA_1 2 `define DATA_2 4 `define DATA_3 8 `define DATA_4 16 `define DATA_5 32 `define DATA_6 64 `define DATA_7 128 module IRC (......); input x,y,z; out alpha, beta; reg alpha, beta; reg [7:0] IDATA [31:0] = {DATA_0, DATA_1, DATA_2, DATA_3, DATA_4, DATA_5, DATA_6, DATA_7}; ... begin .... .... endmodule8 Replies
The trouble is not your defines. With Verilog, you cannot initialise a 2D array in that way.
You should instead use an initial block:
Also, you appear to have only 8 initialisation values, but there are 32 elements in the array to be initialised.initial begin IDATA = DATA_0; IDATA = DATA_1; ... end - Altera_Forum
also
you need apostrophe in front of define symbol. like ... IDATA[0] = `DATA_0; - Altera_Forum
Thanks, it helped me a lot.
I have prepared a script file and am now compiling the files. The commands in the script are as shown below vlog -reportprogress 300 -work work "C:/work/aaa/bbb/ccc/ddd/xly/AIC_package.v" vlog -reportprogress 300 -work work "C:/work/aaa/bbb/ccc/ddd/xly/AICController.v" vlog -reportprogress 300 -work work "C:/work/aaa/bbb/ccc/ddd/xly/sim/AIC_tb.v" # Modifying modelsim.ini # Model Technology ModelSim PE vlog 10.1b Compiler 2012.04 Apr 27 2012 # Model Technology ModelSim PE vlog 10.1b Compiler 2012.04 Apr 27 2012 # ** Error: C:/work/aaa/bbb/ccc/ddd/xly/AICController.v(18): Cannot open `include file "C:/modeltech_pe_10.1b/uvm-1.1a/../verilog_src/uvm-1.1a/src/AIC_package.v". # -- Compiling module AICController I could not figure out why its not getting the include file AIC_Package.v - Altera_Forum
where did you put the file?
try ls command (or dir command in Windows) if the path C:/modeltech_pe_10.1b/uvm-1.1a/../verilog_src/uvm-1.1a/src/AIC_package.v exists ore not? - Altera_Forum
source files are in C:/work/aaa/bbb/ccc/ddd/xly and testbench in C:/work/aaa/bbb/ccc/ddd/xly/sim.
C:/work/aaa/bbb/ccc/ddd/xly/AIC_package.v C:/work/aaa/bbb/ccc/ddd/xly/AICController.v C:/work/aaa/bbb/ccc/ddd/xly/sim/AIC_tb.v The script is run from C:/work/aaa/bbb/ccc/ddd/xly/sim The script contains the following vlog -reportprogress 300 -work work "C:/work/aaa/bbb/ccc/ddd/xly/AIC_package.v" vlog -reportprogress 300 -work work "C:/work/aaa/bbb/ccc/ddd/xly/AICController.v" vlog -reportprogress 300 -work work "C:/work/aaa/bbb/ccc/ddd/xly/sim/AIC_tb.v" vsim work.AIC_tb. I am confused about this path. This does not exist. Actually the file AIC_package.v is never placed in the folder where ModelSim is reporting error. Its placed alongside its main file AICController.v in C:/work/aaa/bbb/ccc/ddd/xly. - Altera_Forum
you should try to create the folder and put the file "AIC_package.v "
I think then the simulation works. just for now , that is enough for you isn't it? try it anyway. - Altera_Forum
What folder to creat? if this is C:/work/aaa/bbb/ccc/ddd/xly, its already created. Also work directory is also created.
the folder you missed.
the message tells you "C:/modeltech_pe_10.1b/uvm-1.1a/../verilog_src/uvm-1.1a/src/AIC_package.v " which means "C:/modeltech_pe_10.1b/verilog_src/uvm-1.1a/src/AIC_package.v " I don't know why modelsim requires that path. but the message tells you, you need it anyway. just try it and research the reason in someday later.
