Hi there,
I'm not able to run (build) even a simple Hello world program in Nios IDE, since it says the required memory is far more than that provided:
onchip_mem is full (hello_world_3.elf section .text). region needs to be 25984 bytes larger. Now, when I add 26k to the onchip memory, the design does not fit on the board.
Please suggest me as to what I should do!
btw, this is the resource usage summary
--- Quote Start ---
Total logic elements 3,526 / 18,752 ( 19 % )
-- Combinational with no register 1571
-- Register only 329
-- Combinational with a register 1626
Logic element usage by number of LUT inputs
-- 4 input functions 1219
-- 3 input functions 1167
-- <=2 input functions 811
Logic elements by mode
-- normal mode 2551
-- arithmetic mode 646
Total registers* 1,955 / 19,649 ( 10 % )
-- Dedicated logic registers 1,955 / 18,752 ( 10 % )
-- I/O registers 0 / 897 ( 0 % )
Total LABs: partially or completely used 279 / 1,172 ( 24 % )
User inserted logic elements 0
Virtual pins 0
I/O pins 22 / 315 ( 7 % )
-- Clock pins 1 / 8 ( 13 % )
Global signals 14
M4Ks 48 / 52 ( 92 % )
Total memory bits 178,880 / 239,616 ( 75 % )
Total RAM block bits 221,184 / 239,616 ( 92 % )
Embedded Multiplier 9-bit elements 0 / 52 ( 0 % )
PLLs 0 / 4 ( 0 % )
Global clocks 14 / 16 ( 88 % )
Average interconnect usage 7%
Peak interconnect usage 19%
Maximum fan-out node clk~clkctrl
Maximum fan-out 1714
Highest non-global fan-out signal quad_sys:quad|quad16_0:the_quad16_0|quad16:the_quad16|nlfsr10:nlfsr_10|wradd[4]~731
Highest non-global fan-out 520
Total fan-out 17597
Average fan-out 3.17
--- Quote End ---
Thank you!
