17 years agoTry to uncheck the option "auto ram replacement" under "assignments -> device -> analysis & synthesis settings"
It would probably help more if you included the summary of the compilation of the SOPC system not just the ip. In the compilation report there is a section called "fitter -> resource usage -> resource utilization by entity" where you can check exactly which resources every component uses. That can maybe help you to find your problem area. //Ola
