Unable to find the User Guide document for "dma_read_master" version 19.2.0
- 1 year ago
Do you have further queries? If no, we shall close this case.
Do you mean the DMA controller? If yes, if this guide is sufficient?
https://www.intel.com/content/www/us/en/docs/programmable/683130/25-1/dma-controller-core.html
- Ashish_Pradhan1 year ago
Hi Kenny Tan,
Thanks for your reply.
The DMA core is separate IP and hence these field descriptions does not suit.
"dma_read_master" (Read Master Intel FPGA IP) and "dma_write_master" (Write Master Intel FPGA IP) are two sub-core of modular Scatter Gather DMA. The user guide which is available for mSGDMA, and their field description seems not working for the above two mentioned IPs. So could you pls provide the document which the tool points to the link mentioned in the earlier post . I need to configure its "command_sink" channel.
Thanks & Regards,
Ashish.
