Timing violation with Altera GPIO in DDR mode
I have a setup violation at the register after the input register. The input register is constrained as described in AN433.
set_input_delay -add_delay -clock virt_adc_clk -min -0.6 [get_ports {ADC_DATA[*]}]
set_input_delay -add_delay -clock virt_adc_clk -min -0.6 -clock_fall [get_ports {ADC_DATA[*]}]
set_input_delay -add_delay -clock virt_adc_clk -max 0.6 [get_ports {ADC_DATA[*]}]
set_input_delay -add_delay -clock virt_adc_clk -max 0.6 -clock_fall [get_ports {ADC_DATA[*]}]
set_false_path -setup -fall_from [get_clocks virt_adc_clk] -rise_to \
[get_clocks CLK262]
set_false_path -setup -rise_from [get_clocks virt_adc_clk] -fall_to \
[get_clocks CLK262]
set_false_path -hold -rise_from [get_clocks virt_adc_clk] -rise_to \
[get_clocks CLK262]
set_false_path -hold -fall_from [get_clocks virt_adc_clk] -fall_to \
[get_clocks CLK262]But now i have the violation after the input register, as you can see in the picture from Timequest.
Do I miss something?
- MRenn
it doesn't fit. I don't know how set up the reference clock.
In AN756 it looks like I need a strobe and a reference clock, but I have only the ADC Clock with 262.144MHz.
- KhaiChein_Y_Intel
You may connect the 262.144MHz clock to the strobe. The reference clock signal is the reference clock for the PLL where you may set the frequency in the IP Parameter Editor.
- MRenn
do I have to use an IO PLL to create the reference clock of 131.072MHzI connected the 262.144MHz clock to the strobe input and to an IO PPL the create the 131.072MHz reference clock. There is still something wrong.
H
- KhaiChein_Y_Intel
I tried to add another clock port to the design for the IOPLL. The error is fixed.
- MRenn
is there a solution without redesigning the hardware?
Thank you.
- KhaiChein_Y_Intel
For design with frequency higher than 200MHz, you have to use PhyLite; and you have to assign a dedicated clock path to the IOPLL.
- MRenn
at the moment I'm trying to get the best timing of our hardware, so I use the gpio instead of PhyLite. There I have a routing problem. I used logiclock regions and design partitions to fix the routing.
I set small logiclock regions in front of the ADC pins, the registers after the pins were placed inside the logiclock region, but the pysical routing seems to be strange as you can see on the picture.
There is a negative setup slack on this path. But the hold slack don't need to be that good as it is.
I also added a qar archive.
Can you tell me why the router routes this long way?
Thank you.
- MRenn
- KhaiChein_Y_Intel
Please allow me some time to look into this.
- KhaiChein_Y_Intel
I tried to remove the logic lock region; the timing is better.
What is the I/O standard you use for the ADC?
- KhaiChein_Y_Intel
