12 years agoTimeQuest Timing Analyzer[Setup slack analysis]
HI,
I am trying to understand how the Time Quest analyzer calculating required setup and hold time.I have written code for register and the clocks are common(50 MHz). As per my understanding data required time for setup calculation = clock arrival time -Tsu - Setup Uncertainty. From the Time Quest analyzer clock arrival time = 22.982ns[ from source latency to clock pessimism] Tsu = 0.021ns Setup Uncertainty = 0ns data required time = 22.982 - 0.021 = 22.961ns. But the tool showing the calculation like below mentioned way, data required time = 22.982 + 0.021 = 23.003ns.? If i am not wrong the data required time should be 22.961ns.Please let me whether my understanding is correct or not? For your ref ------------------------------------------------------------------------------------------------------------------------ path summry:from node q1_s
to node q~reg0
launch clock clk
latch clock clk
data arrival time 3.945
data required time 23.003
slack 19.058 ------------------------------------------------------------------------------------------------------------------------ data required path:
total incr rf type fan out location element
20.000 0.000 source latency
20.000 0.000 1 pin_31 clk clk
20.000 0.000 rr ic 1 ioibuf_x0_y14_n1 clk~input|i
20.990 0.990 rr cell 1 ioibuf_x0_y14_n1 clk~input|o
21.182 0.192 rr ic 1 clkctrl_g4 clk~inputclkctrl|inclk[0]
21.182 0.000 rr cell 2 clkctrl_g4 clk~inputclkctrl|outclk
22.339 1.157 rr ic 1 ff_x1_y10_n17 q~reg0|clk
22.957 0.618 rr cell 1 ff_x1_y10_n17 q~reg0
22.982 0.025 clock pessimism
23.003 0.021 utsu 1 ff_x1_y10_n17 q~reg0
Thanks in advance, Karthi.S
