Simulating FiFo IP using Quartus Pro 23.3
I am attempting to simulate the Fifo IP using the Questa Starter Edition. I am targeting the Stratix 10 GX. It is imperative that I use Quartus Pro and Questa SE to perform these simulations. Here are the steps I am taking,
Steps Im taking: Quartus Prime Pro 23.3, Questa Free Standard
- New Project Wizard
- Dir: D:/Work/QuestaSims/SingleClk24to24Fifo
- Name: Fifo
- Top: FifoTop
- Stratix 10 GX
- No added files
- Select “Questa Intel FPGA edition” for simulation
- Open Fifo IP editor
- Everything Default
- Generate HDL (VHDL)
- Selected Model Sim for simulator script
- Generate TestBench
- Selected VHDL
- Close Parameter editor
- Add tb qsys to project files
- Click "Generate Simulator Setup scripts" under tools
Its at this point that I am unable to make any more progress. I have followed the Questa tutorials provided by Siemans, in the tutorial documents found within the questa install directory. However, these don't account for the added files generated by the IP. I am wondering what steps I need to take after these, so that I have all the needed files to begin simulation?
I have referenced these documents
- Introduction to Intel® FPGA IP Cores
- Intel® Stratix® 10 Embedded Memory User Guide
- Advanced Platform Designer (Part 1): Simulation
I attached an example simulation with the DCFIFO IP. This is run with different testbench and with the IP standalone only (without the fifo_top.v).
I also add usedw signal in it.
You may refer this as a guidelines.Best Regards,
Richard Tan
- RichardT_altera
The next step in the simulation flow, after you have generated the simulation setup script in Quartus, is to write a simulation script.
This is a user guide for the standard simulation flow (without the Qsys). Kindly refer to section [1.5] on how to create the simulation script and then to section [1.6] 'Compile and Simulate the Design' at the following link:
I have also attached a simple zip file (altera_avalon_bfm_master.zip) for a BFM simulation, but this does not include the FIFO IP. It's just to give you a hands-on understanding of how things work.
At some points, you can check out this example design with FIFO IP and FIFO2 (this design does not use the qsys system). Link: https://www.intel.com/content/www/us/en/design-example/714682/intel-stratix-10-fpga-fifo-vs-fifo2-simulation-design-example.html
Richard Tan
- RichardT_altera
Dropping a note to ask if my last reply was helpful to you?
Do you need any further assistance from my side?
Richard Tan
- MaxMcCune
Hi Richard,
Thanks for the response, it has helped me move along this problem. After clicking “Generate Simulator Setup Script.”
- Open Questa
- Change the directory to the mentor directory in my project files
- Then “do mentor_example.do” ( this is a simulator file I wrote, taken from the link provided)
- This opens the Questa Simulator viewer where I can see the objects and attempt to run the sim
However, I am still unable to successfully simulate the FiFo. It seems that Questa doesn’t seem to be communicating with the IP. What I mean is that I can see my test bench stimulus coming through on the waveform viewer but it doesn’t seem to have any effect on the FiFo IP. I have tried running the simulation for different time intervals so that I wasn’t missing anything but no matter what the FiFo doesn’t output any data. It never sends the Empty flag low, or the Full flag high. Even after I wait many CC after sending it data, and overflowing it.
I am attaching my project files in a Zip. The relevant ones are mentor_example.do, fifo_top.v, and FiFoTestBench.v
Thanks for the support!
Max McCune
- RichardT_altera
Richard Tan
- RichardT_altera
Are you able to resolve the issue?
Richard tan
- RichardT_altera
I believe I have provided the solution. With that, I will transition this thread to community support. If you have any further questions or concerns, please don't hesitate to reach out.
Richard Tan
- SOVAD
There is any solution?
