Simulating FiFo IP using Quartus Pro 23.3
- 2 years ago
I attached an example simulation with the DCFIFO IP. This is run with different testbench and with the IP standalone only (without the fifo_top.v).
I also add usedw signal in it.
You may refer this as a guidelines.Best Regards,
Richard Tan
The next step in the simulation flow, after you have generated the simulation setup script in Quartus, is to write a simulation script.
This is a user guide for the standard simulation flow (without the Qsys). Kindly refer to section [1.5] on how to create the simulation script and then to section [1.6] 'Compile and Simulate the Design' at the following link:
I have also attached a simple zip file (altera_avalon_bfm_master.zip) for a BFM simulation, but this does not include the FIFO IP. It's just to give you a hands-on understanding of how things work.
At some points, you can check out this example design with FIFO IP and FIFO2 (this design does not use the qsys system). Link: https://www.intel.com/content/www/us/en/design-example/714682/intel-stratix-10-fpga-fifo-vs-fifo2-simulation-design-example.html
Richard Tan
