Simulating FiFo IP using Quartus Pro 23.3
- 2 years ago
I attached an example simulation with the DCFIFO IP. This is run with different testbench and with the IP standalone only (without the fifo_top.v).
I also add usedw signal in it.
You may refer this as a guidelines.Best Regards,
Richard Tan
Dropping a note to ask if my last reply was helpful to you?
Do you need any further assistance from my side?
Richard Tan
- MaxMcCune2 years ago
Hi Richard,
Thanks for the response, it has helped me move along this problem. After clicking “Generate Simulator Setup Script.”
- Open Questa
- Change the directory to the mentor directory in my project files
- Then “do mentor_example.do” ( this is a simulator file I wrote, taken from the link provided)
- This opens the Questa Simulator viewer where I can see the objects and attempt to run the sim
However, I am still unable to successfully simulate the FiFo. It seems that Questa doesn’t seem to be communicating with the IP. What I mean is that I can see my test bench stimulus coming through on the waveform viewer but it doesn’t seem to have any effect on the FiFo IP. I have tried running the simulation for different time intervals so that I wasn’t missing anything but no matter what the FiFo doesn’t output any data. It never sends the Empty flag low, or the Full flag high. Even after I wait many CC after sending it data, and overflowing it.
I am attaching my project files in a Zip. The relevant ones are mentor_example.do, fifo_top.v, and FiFoTestBench.v
Thanks for the support!
Max McCune
