MaxMcCune
2 years agoSimulating FiFo IP using Quartus Pro 23.3
Hello, I am attempting to simulate the Fifo IP using the Questa Starter Edition. I am targeting the Stratix 10 GX. It is imperative that I use Quartus Pro and Questa SE to perform these simulation...
- 2 years ago
I attached an example simulation with the DCFIFO IP. This is run with different testbench and with the IP standalone only (without the fifo_top.v).
I also add usedw signal in it.
You may refer this as a guidelines.Best Regards,
Richard Tan
RichardT_altera
2 years agoI believe I have provided the solution. With that, I will transition this thread to community support. If you have any further questions or concerns, please don't hesitate to reach out.
Richard Tan
