RTL Simulation fails with: couldn't execute ip-setup-simulation: invalid argument
Hi ,
Error: Failed to run ip-setup-simulation: couldn't execute "c:\altera_pro\26.1\quartus\..\vds\bin\ip-setup-simulation": invalid argument
I have been facing this issue since morning, unable to run the simulation, yesterday it was working fine.
Even tried regenerating IP files also today, but got the same error.
Any help is appreciated.
Sai@2403
- asdfasdf1
I experienced the same issue before, and running Quartus as Administrator solved it for me.
- RichardT_altera
Sai2403 Could you try the suggestion from asdfasdf1 and see if the issue resolved?
Richard Tan- Sai2403
Hi RichardT_altera , can u suggest other method, i cant run it as admistrator , as i dont have credintials.Even if did try, but it needs to run every one as administrator, and am getting below error,though i set it to right environment variable.
Sai@2403
- RichardT_altera
Hi Sai2403
Could you help to share the design (.QAR file) so I could try to duplicate this issue from my side?
Do you run the simulation using the RTL Simulation (also called Nativelink simulation flow)?
Additionally, which OS are you using?
Richard Tan
