Sai2403
4 months agoRTL Simulation fails with: couldn't execute ip-setup-simulation: invalid argument
Hi , Error: Failed to run ip-setup-simulation: couldn't execute "c:\altera_pro\26.1\quartus\..\vds\bin\ip-setup-simulation": invalid argument I have been facing this issue since morning, unab...
RichardT_altera
4 months agoSai2403 Could you try the suggestion from asdfasdf1 and see if the issue resolved?
Richard Tan
Sai2403
4 months agoHi RichardT_altera , can u suggest other method, i cant run it as admistrator , as i dont have credintials.Even if did try, but it needs to run every one as administrator, and am getting below error,though i set it to right environment variable.
Sai@2403
- RichardT_altera4 months ago
Could you check with your IT team to confirm that you have read and write access to the Quartus installation folder?
Additionally, please check if there were any changes to the machine before and after the error occurred. This may help identify the root cause.
Richard Tan - Sai24034 months ago
Hi RichardT_altera , try this simulation
