9 years ago
ROM and RAM connection
Im trying to connect ROM with RAM blocks,for this Im write top level entity and connected output of ROM with RAM
This is code for ROM
LIBRARY ieee;    USE ieee.std_logic_1164.all;
     use STD.textio.all;
    ENTITY sync_rom IS
     PORT (
      clock: IN std_logic;
      address: IN integer range 0 to 511;
      data_a_i: OUT integer range 0 to 255;
       data_b_q: OUT integer range 0 to 255
    END sync_rom;
    ARCHITECTURE rtl OF sync_rom IS
    BEGIN
    PROCESS (clock)
     BEGIN
     IF rising_edge (clock) THEN
      CASE address IS
       WHEN 0 =>
            data_a_i <= 128;
            data_b_q <= 128;
       WHEN 16 =>
             data_a_i <= 128;
             data_b_q <= 128;
         WHEN 70 =>
             data_a_i <= 128;
             data_b_q <= 128;
         WHEN 400 =>
             data_a_i <= 128;
             data_b_q <= 128;
       WHEN OTHERS  =>
              data_a_i <= 0;
             data_b_q <= 0;
      END CASE;
     END IF;
     END PROCESS;
END rtl;
This is code for RAM
library ieee;use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity dp_ram_rbw_scl is
  generic (
    DATA_WIDTH : integer := 256;
    ADDR_WIDTH : integer := 256
  port (
-- common clock
    clk    : in  std_logic;
    -- Port A
    we_a   : in  std_logic;
    addr_a : in  std_logic_vector(ADDR_WIDTH-1 downto 0);
    data_a : in  std_logic_vector(DATA_WIDTH-1 downto 0);
    q_a    : out std_logic_vector(DATA_WIDTH-1 downto 0);
    -- Port B
    we_b   : in  std_logic;
    addr_b : in  std_logic_vector(ADDR_WIDTH-1 downto 0);
    data_b : in  std_logic_vector(DATA_WIDTH-1 downto 0);
    q_b    : out std_logic_vector(DATA_WIDTH-1 downto 0)
end dp_ram_rbw_scl;
architecture rtl of dp_ram_rbw_scl is
  -- Shared memory
  type mem_type is array ((2**ADDR_WIDTH)-1 downto 0) of std_logic_vector(DATA_WIDTH-1 downto 0);
  shared variable mem : mem_type;
begin
-- Port A
  process(clk)
  begin
    if(clk'event and clk = '1') then
      q_a <= mem(conv_integer(addr_a));
      if(we_a = '1') then
        mem(conv_integer(addr_a)) := data_a;
      end if;
    end if;
  end process;
-- Port B
  process(clk)
  begin
      q_b <= mem(conv_integer(addr_b));
      if(we_b = '1') then
        mem(conv_integer(addr_b)) := data_b;
      end if;
    end if;
  end process;
end rtl;
after this this I write TOP level entity
    use ieee.numeric_std.all ;
    use ieee.math_real.all ;
    use ieee.math_complex.all ;
entity ROMRAM is
    port (
       data_b_q: OUT integer range 0 to 255;
        ADDR_WIDTH : integer := 256;
        clk    : in  std_logic;
        q_b    : out std_logic_vector(DATA_WIDTH-1 downto 0);
end ROMRAM;
architecture rtl of ROMRAM is
--- Component decalarartion
Component sync_rom is
    port(
end component;
Component dp_ram_rbw_scl is
generic (
         port (
        clk    : in  std_logic;
        addr_a : in  std_logic_vector(DATA_WIDTH-1 downto 0) ;
        data_a : in  std_logic_vector(DATA_WIDTH-1 downto 0) ;
        addr_b : in  std_logic_vector(ADDR_WIDTH-1 downto 0) ;
        data_b : in  std_logic_vector(DATA_WIDTH-1 downto 0) ;
end component;
for all : sync_rom use entity work.sync_rom(rtl);
--for all : dp_ram_rbw_scl use entity work.dp_ram_rbw_scl(rtl);
--Signal     data_a_i: integer range 0 to 255;
--data_b_q_a: std_logic_vector(255 downto 0);--interanal signals
begin
--inst : dp_ram_rbw_scl port map ( addr_a=> addr_a,
--clk=> clk,we_a=>we_a,data_a=>data_a,addr_b=>addr_b,data_b=>data_b,we_b=>we_b);
q_a<= addr_a and data_a;
-- Component Instantiation
C1: sync_rom Port map (
                                clock => clock,
                                address =>address,
                                data_a_i =>data_a_i,
                                data_b_q =>data_b_q
C2: dp_ram_rbw_scl Port map (
                                    clk=>clk,
                                    we_a=>we_a,
                                    addr_a=>addr_a,
                                    data_a =>data_a,
                                    q_a=>q_a,
                                    we_b=>we_b,
                                    addr_b=>addr_b,
                                    data_b =>data_b,
                                    q_b=>q_b
                                data_a_i<=to_integer ( unsigned (data_a));
                                data_b_q<=to_integer ( unsigned (data_b));
end rtl;
But this code doesnt work/Could you please give me some hints for solution? I want to connect data_a_i(ROM) with data_a(RAM) and data_b_q(ROM) with data_b(RAM)
I get next errors
Error (10346): VHDL error at Vhdl2.vhd(70): formal port or parameter "addr_a" must have actual or default value
Error (10346): VHDL error at Vhdl2.vhd(70): formal port or parameter "data_a" must have actual or default value
Error (10346): VHDL error at Vhdl2.vhd(70): formal port or parameter "addr_b" must have actual or default value
Error (10346): VHDL error at Vhdl2.vhd(70): formal port or parameter "data_b" must have actual or default value
