10 years agoROM and RAM connection
Hello, Im trying to connect ROM with RAM blocks,for this Im write top level entity and connected output of ROM with RAM This is code for ROM LIBRARY ieee; USE ieee.std_logic_1164.all;
10 years agoThanks for replay,I changed as you said,but code still has some errors
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_signed.all;
use ieee.numeric_std.all ;
use ieee.math_real.all ;
use ieee.math_complex.all ;
entity ROMRAM is
port (
CLOC: IN std_logic;
ADD: IN integer range 0 to 511;
DATA_WIDTHi : integer := 256;
ADDR_WIDTHi : integer := 256;
data_a : in std_logic_vector(ADDR_WIDTHi-1 downto 0);
data_b : in std_logic_vector(ADDR_WIDTHi-1 downto 0);
data_a_i : integer range 0 to 255;
data_b_q : integer range 0 to 255;
clk : in std_logic;
we_ai : in std_logic;
addr_ai : in std_logic_vector(ADDR_WIDTHi-1 downto 0);
q_ai : out std_logic_vector(DATA_WIDTHi-1 downto 0);
we_bq : in std_logic;
addr_bq : in std_logic_vector(ADDR_WIDTHi-1 downto 0);
q_bq : out std_logic_vector(DATA_WIDTHi-1 downto 0));
end ROMRAM;
architecture rtl of ROMRAM is
--- Component decalarartion
Component sync_rom is
port(
clock: IN std_logic;
address: IN integer range 0 to 511;
data_a_i: OUT integer range 0 to 255;
data_b_q: OUT integer range 0 to 255
end component;
Component dp_ram_rbw_scl is
generic (
DATA_WIDTH : integer := 256;
ADDR_WIDTH : integer := 256
port(
clk : in std_logic;
we_a : in std_logic;
addr_a : in std_logic_vector(ADDR_WIDTH-1 downto 0) ;
data_a : in std_logic_vector(DATA_WIDTH-1 downto 0) ;
q_a : out std_logic_vector(DATA_WIDTH-1 downto 0);
we_b : in std_logic;
addr_b : in std_logic_vector(ADDR_WIDTH-1 downto 0) ;
data_b : in std_logic_vector(DATA_WIDTH-1 downto 0) ;
q_b : out std_logic_vector(DATA_WIDTH-1 downto 0)
end component;
for all : sync_rom use entity work.sync_rom(rtl);
for all : dp_ram_rbw_scl use entity work.dp_ram_rbw_scl(rtl);
Signal data_a_i_i: integer range 0 to 255;--interanal signals
Signal data_b_q_i: integer range 0 to 255;--interanal signals
begin
-- Component Instantiation
C1: sync_rom Port map (
clock => CLOC,
address =>ADD,
data_a_i =>data_a_i_i,
data_b_q =>data_b_q_i
C2: dp_ram_rbw_scl
Port map (
clk=>CLOC,
we_a=>we_ai,
addr_a=>addr_ai,
data_a =>data_a,
q_a=>q_ai,
we_b=>we_bq,
addr_b=>addr_bq,
data_b =>data_b,
q_b=>q_bq
data_a_i_i<= to_integer(unsigned(data_a));
data_b_q_i<= to_integer(unsigned(data_b));
end rtl;
errors Warning (10036): Verilog HDL or VHDL warning at Vhdl2.vhd(57): object "data_a_i_i" assigned a value but never readWarning (10036): Verilog HDL or VHDL warning at Vhdl2.vhd(58): object "data_b_q_i" assigned a value but never read
Error (10346): VHDL error at Vhdl2.vhd(70): formal port or parameter "addr_a" must have actual or default value
Error (10346): VHDL error at Vhdl2.vhd(70): formal port or parameter "data_a" must have actual or default value
Error (10346): VHDL error at Vhdl2.vhd(70): formal port or parameter "addr_b" must have actual or default value
Error (10346): VHDL error at Vhdl2.vhd(70): formal port or parameter "data_b" must have actual or default value
