10 years agoROM and RAM connection
Hello, Im trying to connect ROM with RAM blocks,for this Im write top level entity and connected output of ROM with RAM This is code for ROM LIBRARY ieee; USE ieee.std_logic_1164.all;
10 years ago --- Quote Start --- any help)? --- Quote End --- use same type for port map then change type afterwards a required. Normally we do std_logic_vector at interface, signed/unsigned or integer internally
