10 years agoROM and RAM connection
Im trying to connect ROM with RAM blocks,for this Im write top level entity and connected output of ROM with RAM This is code for ROMLIBRARY ieee; USE ieee.std_logic_1164.all;
use STD.textio.all;
ENTITY sync_rom IS
PORT (
clock: IN std_logic;
address: IN integer range 0 to 511;
data_a_i: OUT integer range 0 to 255;
data_b_q: OUT integer range 0 to 255
END sync_rom;
ARCHITECTURE rtl OF sync_rom IS
BEGIN
PROCESS (clock)
BEGIN
IF rising_edge (clock) THEN
CASE address IS
WHEN 0 =>
data_a_i <= 128;
data_b_q <= 128;
WHEN 16 =>
data_a_i <= 128;
data_b_q <= 128;
WHEN 70 =>
data_a_i <= 128;
data_b_q <= 128;
WHEN 400 =>
data_a_i <= 128;
data_b_q <= 128;
WHEN OTHERS =>
data_a_i <= 0;
data_b_q <= 0;
END CASE;
END IF;
END PROCESS;
END rtl;
This is code for RAM library ieee;use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity dp_ram_rbw_scl is
generic (
DATA_WIDTH : integer := 256;
ADDR_WIDTH : integer := 256
port (
-- common clock
clk : in std_logic;
-- Port A
we_a : in std_logic;
addr_a : in std_logic_vector(ADDR_WIDTH-1 downto 0);
data_a : in std_logic_vector(DATA_WIDTH-1 downto 0);
q_a : out std_logic_vector(DATA_WIDTH-1 downto 0);
-- Port B
we_b : in std_logic;
addr_b : in std_logic_vector(ADDR_WIDTH-1 downto 0);
data_b : in std_logic_vector(DATA_WIDTH-1 downto 0);
q_b : out std_logic_vector(DATA_WIDTH-1 downto 0)
end dp_ram_rbw_scl;
architecture rtl of dp_ram_rbw_scl is
-- Shared memory
type mem_type is array ((2**ADDR_WIDTH)-1 downto 0) of std_logic_vector(DATA_WIDTH-1 downto 0);
shared variable mem : mem_type;
begin
-- Port A
process(clk)
begin
if(clk'event and clk = '1') then
q_a <= mem(conv_integer(addr_a));
if(we_a = '1') then
mem(conv_integer(addr_a)) := data_a;
end if;
end if;
end process;
-- Port B
process(clk)
begin
q_b <= mem(conv_integer(addr_b));
if(we_b = '1') then
mem(conv_integer(addr_b)) := data_b;
end if;
end if;
end process;
end rtl;
after this this I write TOP level entity library ieee;use ieee.std_logic_1164.all;
use ieee.numeric_std.all ;
use ieee.math_real.all ;
use ieee.math_complex.all ;
entity ROMRAM is
port (
data_b_q: OUT integer range 0 to 255;
ADDR_WIDTH : integer := 256;
clk : in std_logic;
q_b : out std_logic_vector(DATA_WIDTH-1 downto 0);
end ROMRAM;
architecture rtl of ROMRAM is
--- Component decalarartion
Component sync_rom is
port(
end component;
Component dp_ram_rbw_scl is
generic (
port (
clk : in std_logic;
addr_a : in std_logic_vector(DATA_WIDTH-1 downto 0) ;
data_a : in std_logic_vector(DATA_WIDTH-1 downto 0) ;
addr_b : in std_logic_vector(ADDR_WIDTH-1 downto 0) ;
data_b : in std_logic_vector(DATA_WIDTH-1 downto 0) ;
end component;
for all : sync_rom use entity work.sync_rom(rtl);
--for all : dp_ram_rbw_scl use entity work.dp_ram_rbw_scl(rtl);
--Signal data_a_i: integer range 0 to 255;
--data_b_q_a: std_logic_vector(255 downto 0);--interanal signals
begin
--inst : dp_ram_rbw_scl port map ( addr_a=> addr_a,
--clk=> clk,we_a=>we_a,data_a=>data_a,addr_b=>addr_b,data_b=>data_b,we_b=>we_b);
q_a<= addr_a and data_a;
-- Component Instantiation
C1: sync_rom Port map (
clock => clock,
address =>address,
data_a_i =>data_a_i,
data_b_q =>data_b_q
C2: dp_ram_rbw_scl Port map (
clk=>clk,
we_a=>we_a,
addr_a=>addr_a,
data_a =>data_a,
q_a=>q_a,
we_b=>we_b,
addr_b=>addr_b,
data_b =>data_b,
q_b=>q_b
data_a_i<=to_integer ( unsigned (data_a));
data_b_q<=to_integer ( unsigned (data_b));
end rtl;
But this code doesnt work/Could you please give me some hints for solution? I want to connect data_a_i(ROM) with data_a(RAM) and data_b_q(ROM) with data_b(RAM) I get next errors Error (10346): VHDL error at Vhdl2.vhd(70): formal port or parameter "addr_a" must have actual or default value Error (10346): VHDL error at Vhdl2.vhd(70): formal port or parameter "data_a" must have actual or default value Error (10346): VHDL error at Vhdl2.vhd(70): formal port or parameter "addr_b" must have actual or default value Error (10346): VHDL error at Vhdl2.vhd(70): formal port or parameter "data_b" must have actual or default value37 Replies
you haven't declared signals in top level, you just copied names of your lower level modules.
On the top level I should you use different names of the signals?When I define entity ROMRAM and the lower entity I should remain the same?
--- Quote Start --- On the top level I should you use different names of the signals?When I define entity ROMRAM and the lower entity I should remain the same? --- Quote End --- use any name but declare them. The top level does not view signals inside lower modules as declared at top level - Altera_Forum
Thanks)I got it)pls say how I can convert std_logic vector and integer?I do it like this but not works
C2: dp_ram_rbw_scl Port map ( clk=>CLOC, we_a=>we_ai, addr_a=>addr_ai, data_a =>data_a_i, q_a=>q_ai, we_b=>we_bq, addr_b=>addr_bq, data_b =>data_b_q, q_b=>q_bq ); data_a_i<=to_integer ( unsigned (data_a)); data_b_q<=to_integer ( unsigned (data_b)); end rtl; - Altera_Forum
data_i <=to_integer(unsigned(data_s));
is ok if data_i is integer ad data_s is std_logic_vector and you have library numeric_std - Altera_Forum
yes.data_i is integer.
data_s is std_logic_vector Im using library numeric_std but I have error Error (10476): VHDL error at Vhdl2.vhd(67): type of identifier "data_a_i" does not agree with its usage as "std_logic_vector" type - Altera_Forum
--- Quote Start --- yes.data_i is integer. data_s is std_logic_vector Im using library numeric_std but I have error Error (10476): VHDL error at Vhdl2.vhd(67): type of identifier "data_a_i" does not agree with its usage as "std_logic_vector" type --- Quote End --- double check your declarations or copy your code snippet here - Altera_Forum
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; use ieee.numeric_std.all ; use ieee.math_real.all ; use ieee.math_complex.all ; entity ROMRAM is port ( CLOC: IN std_logic; ADD: IN integer range 0 to 511; DATA_WIDTHi : integer := 256; ADDR_WIDTHi : integer := 256; clk : in std_logic; we_ai : in std_logic; addr_ai : in std_logic_vector(ADDR_WIDTHi-1 downto 0); q_ai : out std_logic_vector(DATA_WIDTHi-1 downto 0); we_bq : in std_logic; addr_bq : in std_logic_vector(ADDR_WIDTHi-1 downto 0); q_bq : out std_logic_vector(DATA_WIDTHi-1 downto 0)); end ROMRAM; architecture rtl of ROMRAM is --- Component decalarartion Component sync_rom is port( clock: IN std_logic; address: IN integer range 0 to 511; data_a_i: OUT integer range 0 to 255; data_b_q: OUT integer range 0 to 255 ); end component; Component dp_ram_rbw_scl is generic ( DATA_WIDTH : integer := 256; ADDR_WIDTH : integer := 256 ); port( clk : in std_logic; we_a : in std_logic; addr_a : in std_logic_vector(ADDR_WIDTH-1 downto 0) ; data_a : in std_logic_vector(DATA_WIDTH-1 downto 0) ; q_a : out std_logic_vector(DATA_WIDTH-1 downto 0); we_b : in std_logic; addr_b : in std_logic_vector(ADDR_WIDTH-1 downto 0) ; data_b : in std_logic_vector(DATA_WIDTH-1 downto 0) ; q_b : out std_logic_vector(DATA_WIDTH-1 downto 0) ); end component; for all : sync_rom use entity work.sync_rom(rtl); for all : dp_ram_rbw_scl use entity work.dp_ram_rbw_scl(rtl); Signal data_a_i: integer range 0 to 255;--interanal signals Signal data_b_q: integer range 0 to 255;--interanal signals begin -- Component Instantiation C1: sync_rom Port map ( clock => CLOC, address =>ADD, data_a_i =>data_a_i, data_b_q =>data_b_q ); C2: dp_ram_rbw_scl Port map ( clk=>CLOC, we_a=>we_ai, addr_a=>addr_ai, data_a =>data_a_i, q_a=>q_ai, we_b=>we_bq, addr_b=>addr_bq, data_b =>data_b_q, q_b=>q_bq ); data_a_i<=to_integer(unsigned(data_a)); data_b_q<=to_integer(unsigned(data_b)); end rtl; - Altera_Forum
c2 data_a is std_logic_vector and you are connecting it to integer..
ok/what should i do.how to convert it or?
