wa_itd
9 days agoThank you, however my custom component, when instantiated in Platform Designer, is an IP core. So, I think I am unable to change the library for individual files within an IP core (but I can change the library which the entire IP core is compiled into).
So I might have to think of some kind of workaround.
ShengN_altera
8 days agochange library "mylib" to "work" ?
- wa_itd8 days ago
So in other words, ditch the library and just use "work" ? This is what I was trying to avoid, but if it is simply not possible in Quartus, then I'll have no other option.
- ShengN_altera8 days ago
Inside IP, you can only use work. Or move that file out of the IP to use mylib
