Quartus Licensing Issue
Recent versions of Quartus (both Std & Pro) for WIndows introduced a new problem with the license management (for node-locked licenses) which is a pain to work around.
In Tools > License Setup panel, "NIC ID", a lot of "ghost" adapters appear now, while the normal behavior was to see the MAC Addresses of the Ethernet Adapters that show up in the device manager and in ipconfig /all. This seems aggravated by the use of the "Get no-cost licenses" button that apparently generates a license file for a (or many !) new virtual adapter(s)...
I call them "ghost" or virtual because they don't show up in the usual commands (getmac /v, ipconfig /all, lmhostid etc) and do not correspond to a physical peripheral (network card).
To make things worse, Quartus can apparently only handle a maximum of 10 (ten) Ids. The consequence is that your "real" adapter may fall out of the list and a node-locked license for this adapter becomes unusable.
The only work around I found was to use the device manager, display the hidden devices, and to disable the numerous Microsoft "WAN Miniport" in the Network cards category. This should reduce the list enough to see the "real" address used for your node-locked license.
I proposed a solution : allow the manual editing of the NIC Ids list (save in quartus.ini or registry).
But today it seems a bit hard to be heard...
- ShengN_altera
Could you provide any screenshot for better understanding?
- BCuze
Screenshots of what ? A list of 10 NIC IDs ? How would this provide more information than I already did ?
Just forward the information I have provided to the development team. I described precisely the issue.
They can contact me if needed.- ShengN_altera
Can screenshot your License Setup NIC ID section? And screenshot the real adapter that you want to use which fall out of the list
- sstrell
Yeah, I don't understand. If you generate a license with a MAC ID for an actual network adaptor in your computer, how does it "fall out?" A license you generate is tied to the MAC ID you enter at the SSLC so unless you are able to remove the network adaptor hardware, it's not clear how this could happen.
