BCuze
1 month agoQuartus Licensing Issue
Recent versions of Quartus (both Std & Pro) for WIndows introduced a new problem with the license management (for node-locked licenses) which is a pain to work around. In Tools > License Setup panel...
sstrell
1 month agoYeah, I don't understand. If you generate a license with a MAC ID for an actual network adaptor in your computer, how does it "fall out?" A license you generate is tied to the MAC ID you enter at the SSLC so unless you are able to remove the network adaptor hardware, it's not clear how this could happen.
