Yes all thing seems to be correct.... in vhdl file and block/schematic
I've design some vhdl files and some .bdf file from them but with top-level design but without design hierarchy but I think that I need to compile the project to be able to assign hierarchy to files automatically or manually I don't know....
but here is the complete report:
Date: September 20, 2008 Project: FWD_Comp
Info: *******************************************************************
Info: Running Quartus II Analysis & Elaboration
Info: Version 7.2 Build 151 09/26/2007 SJ Full Version
Info: Processing started: Sat Sep 20 19:20:50 2008
Info: Command: quartus_map --read_settings_files=on --write_settings_files=off FWD_Comp -c Rev3
--analysis_and_elaboration
Info: Found 2 design units, including 1 entities, in source file Ser.vhd
Info: Found design unit 1: Ser-Ser_arch
Info: Found entity 1: Ser
Info: Found 1 design units, including 1 entities, in source file FWD_Comp.bdf
Info: Found entity 1: FWD_Comp
Info: Found 2 design units, including 1 entities, in source file Pkt_Mgr_Shift_Reg.vhd
Info: Found design unit 1: Pkt_Mgr_Shift_Reg-Pkt_Mgr_SR_Arch
Info: Found entity 1: Pkt_Mgr_Shift_Reg
Info: Found 2 design units, including 1 entities, in source file Pkt_Mgr_Detector.vhd
Info: Found design unit 1: Pkt_Mgr_Detector-Pkt_Mgr_Detector_Arch
Info: Found entity 1: Pkt_Mgr_Detector
Info: Found 2 design units, including 1 entities, in source file Deserializer_Sync_Shift_Reg.vhd
Info: Found design unit 1: basic_shift_register-rtl
Info: Found entity 1: basic_shift_register
Info: Found 1 design units, including 1 entities, in source file Pkt_Mgr.bdf
Info: Found 1 design units, including 1 entities, in source file FWD_Input_BDF.bdf
Info: Found entity 1: FWD_Input_BDF
Info: Found 2 design units, including 1 entities, in source file binary_counter.vhd
Info: Found design unit 1: binary_counter-rtl
Info: Found entity 1: binary_counter
Info: Found 2 design units, including 1 entities, in source file Des.vhd
Info: Found design unit 1: Des-Des_Arch
Info: Found entity 1: Des
Info: Found 2 design units, including 1 entities, in source file BQ_data.vhd
Info: Found design unit 1: BQ_data-arch_bq_data
Info: Found entity 1: BQ_data
Info: Found 2 design units, including 1 entities, in source file BQ_counter.vhd
Info: Found design unit 1: BQ_counter-arch_bq_counter
Info: Found entity 1: BQ_counter
Info: Found 1 design units, including 1 entities, in source file CAM_RAM_BDF.bdf
Info: Found entity 1: CAM_RAM_BDF
Info: Elaborating entity "FWD_Comp" for the top level hierarchy
Warning: Undeclared parameter MTU
Error: Bus range for signal "port "label_out[MTU-1..MTU-32]" (ID FWD_Input_BDF:inst1)" must be a
number
number
Error: Bus range for signal "port "data_out1[MTU-33..0]" (ID FWD_Input_BDF:inst1)" must be a number
Warning: Undeclared parameter pkt_len_counter
Error: Bus range for signal "port "counter_out6[pkt_len_counter-1..0]" (ID FWD_Input_BDF:inst1)" must
be a number
Error: Can't elaborate top-level user hierarchy
Error: Quartus II Analysis & Elaboration was unsuccessful. 5 errors, 4 warnings
Info: Allocated 154 megabytes of memory during processing
Error: Processing ended: Sat Sep 20 19:20:59 2008
Error: Elapsed time: 00:00:09
