Quartus 23 abort (core dump) on Linux
This started happening yesterday; I don't know why it's happening. Here's the output from the strace program:
Edit: I have reinstalled my entire OS to isolate the problem. It did not solve the issue.
I installed it on Arch Linux, via the AUR. The issue has been found out and is described within the comments at the AUR page. It has to do with the fontconfig library.
- RichardT_altera
Are you trying to install Quartus Standard 23.1 in OS RHEL 7.2?
The OS RHEL 7.2 is not officially supported.
Please check the supported OS list for Quartus Standard 23.1:
Intel® Quartus® Prime Standard Edition Version 23.1 readme.txt
FYI, You may try to install on the non-supported OS but you will have to bear your own risk and there will be no technical support as well.
Additionally, how do you install Quartus?
Are you install using the 'Quartus Prime Installer' or the 'Complete Download .tar file'?
Richard Tan
- Nirva
- Ahmed-Ramsey
Can you mention how did you solve it ?
- Nirva
The issue was the update to fontconfig. There are a few ways to solve it. Installing fontconfig-ubuntu from the AUR, which replaces and provides fontconfig, was the way I solved it.
You can also edit your pacman.conf to ignore updates to fontconfig and roll it back to the 2-15 version
Note that keeping outdated packages like this on your system could cause many problems.
- RichardT_altera
I'm pleased to know that your issue has been resolved.
Now, I will transitioning this thread to community support. If you have any further questions or concerns, please don't hesitate to reach out. Please login to https://supporttickets.intel.com/s/?language=en_US , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support.
Richard Tan
